Hey all,
This is going to be my first time building a SFF pc, I've always made full towers before, and I was wondering if you guys can help me out with my build (all components are going to fit, enough performance, etc.)
I will be mostly gaming on a 1920x1200 monitor, and portability of the system is a big plus (not too heavy, easy to carry around).
Anyway, here are the specs I'm looking at:
CPU: Core 2 Duo E8400 (http://www.newegg.com/Product/Product.aspx?Item=N82E16819115037)
MOBO: DFI Lan Party Jr. (http://www.newegg.com/Product/Product.aspx?Item=N82E16813136055)
Video Cards: 2x ATI 4850 1GB Crossfire (http://www.newegg.com/Product/Product.aspx?Item=N82E16814161245) - or should I go single 4850 or single Nvidia GTX 260
CASE: Thermaltake VF1000BWS (http://www.newegg.com/Product/Product.aspx?Item=N82E16811133035)
Memory: 4gb (2x2gb) G-skill DDR2 1066 (http://www.newegg.com/Product/Product.aspx?Item=N82E16820231166)
HSF: SILVERSTONE NT06-E (http://www.newegg.com/Product/Product.aspx?Item=N82E16835220033) - going to have a PSU with a fan in the bottom hanging over this for the airflow - can you guys recommend a good one?
HD: OCZ SSD 64Gb (http://www.newegg.com/Product/Product.aspx?Item=N82E16820227344) - OS drive - got this for $80, I think that's a steal
Seagate ST3640323AS 640GB - (http://www.newegg.com/Product/Product.aspx?Item=N82E16822148335) - games and storage drive
PSU: suggestions from you guys
Will I be able to game decently with these components? Will these fit? Are there better options (better bang for the buck, etc...)? Any help/input will be appreciated. Thanks.
