First time building a computer. Windows XP problem on first boot
I just finished building my first computer. And all I needed to do was to boot the thing up. I then grab my brand new Windows XP Home Edition thinking it was the full edition (it's an upgrade thingy)and then I get this message telling me to put in a previous Windows product like windows 95, 98 etc.
So I find an old Windows 98 CD and put it in and it does something for a minute then it gives me a message to re-enter the Windows XP Home Edition Upgrade disc. After I do that, it gives me the option to create a hard disk partition to load windows onto, something about formating it using the NTFS file system. So I click enter and the computer starts to partition, takes a while too. After it's done the computer restarts and the Windows XP logo appears, followed by a screen which displays the current downloading process...something like this:
*collecting information
*dynamic update
*preparing installation
*etc.
*set up will complete in approximately 39 minutes
So everything looks fine, but suddenly I get a message that says ''error retrieving product key'' ''fatal error''
So now when I turn on the PC it seems that Windows XP is partially installed and It repeats the very same process *collecting information *dynamic Update ec...+'error product key''
Anyone have an idea how I can fix this? I just built this computer. Have I permanently damaged the harddrive?
Can I reset the whole process and get rid of the partially downloaded Windows XP screen? Anyone have any solutions to this problem?
Lol...no...software isn't going to kill hardware. What kind of XP Home CD is it? Is this a retail CD, or did it come with some other kind of computer? It sounds like the disc was meant more for re-imagine an OEM machine, and is BIOS-locked into only working on that brand computer.
How do I get out of this weird xp screen:
''collecting information
*dynamic update
*etc.
I want to install windows 98. Can I reset everything like the partition stuff to its original state? I simply want to delete the one I made previously and recreate it... erasing the harddisk drive and removing that partial XP installation.
There are a number of free tools out there that will clear the drive completely. Whoever made your hard drive should have one on their website as well.
