First time building a computer please advise
MassConfusion
Yeah I am a complete newb and any help would be much appreciated
Right now I am having trouble choosing between a Crosshair II Formula and a Foxconn Destroyer. Which would work best with dual NVIDIA GeForce GTX 295 video cards. I also have a 16Gb G. Skill MQ Quad Kit for memory, would either of motherboards be able to handle that?:confused:
1. What is your budget?
2. Any reason why you picked those boards or decided to go with an AMD system? Intel's Core i7 CPUs are faster than AMD's offerings, and scale better with multi-GPU setups. For maximum performance with those two GTX295s, an i7 system would probably be a better option. You would have to purchase a new set of RAM though, since Core i7 systems require DDR3.
3. What are the other components you will be using (power supply, monitor, case, etc.)?
Right now my budget is not much a problem, I'm just looking for parts and will buy them when I have the money.
The reason why I choose an AMD system is solely on the fact that I was using a setup that I have already seen. So if Intel Core i7 is better than AMD than I am all for it.
The components I was thinking about are:
Case: Lian Li PC-P80
Harddrive: WD Caviar Green 1Tb
LG 8x Super Multi Blue-Ray Writer
Sound Blaster X-Fi Titanium Fatal1ty Professional Series
For the power supply and cooling and RAM I don't know what I will need, especially now when the motherboard I was looking at is not that great, and
Probably need a good 750w power supply like a Corsair. Get modular as it makes cable management easier.
For gaming, which one is better Intel or AMD
Better for gaming? Well you are going to get a ton of subjective opinions about that if you are talking about anything less than a Core i7 driven rig. However, if price is really not much of a problem then I am pretty sure no one would dispute that Core i7 is top dog by a good margin right now. It is a good deal more expensive though.
If you're looking for performance, drop the Green drive. They're designed for power-savings, while the Black drives are designed for performance. The WD 640GB (the older 6400AAKS or newer 6401AALS) is a 2-platter design and thus performs quite well due to the high data density. Another option is to keep the Green 1TB (or similar) for general data storage, and buy a Raptor or SSD for actually running your programs. You'll get speed on apps and still have lots of storage room.
