First time builder needs help
godra
Would all these components fit inside the case? Any other advise is more then welcome as well!
Gigabyte Poseidon Case
MSI 8800GTS
Zalman CNPS9500 LED
Core 2 Duo E6600
ABIT AW9D-MAX
G.SKILL 2GB DDR2 800 F2-6400PHU2-2GBHZ
SAMSUNG 18X DVD±RW SATA SH-S183L
Raptor 74GB 16MB
Zalman ZM600-HP 600w Modular PS
yes, everything should fit in that case.
Since you are spending around $160 on a power supply, I would suggest you get a OCZ GameXStream 700watt Power Supply. I have one and it is very stable and quiet. Mine's been running stable since June 2006.
Zalman PS is $129 at ZZF, including shiping. I selected it based on review found at www.jonnyguru.com. I'll have a look at the one you've suggested. Thanks!
