First time builder, need advice, post purchase
Lakedaimon
Ok since you are the experts ill put down what i already ordered maybe you guys can tell me if i did ok, andi still need a couple parts, so with this stuff in mind maybe you can help me pick the Power Supply and Case
here goes
eVGA 256-P2-N518 Geforce 7800GT 256MB 256-bit GDDR3 VIVO PCI Express x16 Video Card
eVGA 133-K8-NF41 Socket 939 NVIDIA nForce4 SLI ATX AMD Motherboard
AMD Athlon 64 3700+ San Diego 1GHz FSB 1MB L2 Cache Socket 939 Processor
CORSAIR XMS 2GB (2 x 1GB) 184-Pin DDR SDRAM Unbuffered DDR 400 (PC 3200) Dual Channel Kit System Memory
thats what i got, still need power supply and case
Lookin to stay relatively cheap, so keep that in mind,
Hows the stuff i got?
Whats a good Power Supply for the money?
And when it comes to case, i like futuristic lookin but still good, for example i like the NZXT stuff, but if there is other better stuff for same or better price any info would be cool.
Thanks in advance this Forum is the best
Previous poster nailed it. Just be sure not to get a MicroATX case out of the list posted.
Since your a first time builder, you might want to have a guide nearby for quick reference. I recommend this one.
This PSU is fine but just to be on the safe side - I don't believe it to be enough to be honest. You have quite a powerful PC. It's going to need a lot of juice. While the Smart Power is good, it won't have those steady 3% clean regulation that the TruPower has. Either way, as long as you don't overclock or push anything, the SmartPower will be fine.
-J.
