I am building my first SSF computer. I am hoping for a little help filling in the gaps I am missing.
It has been awhile since my last PC build. This PC will mainly be used for CAD applications such as Autocad(2D) and Solidworks(3D). Also, some gaming, Steam, WoW, and Others. (I am Mac person, but using Windows via Parallel Desktops just isn't working for my 3D CAD work.)
Other then the Case, I honestly have just looked up parts via Newegg looking at reviews. If there are more cost efficient products or better please let me know.
Case: Lanbox Lite
Mobo: GIGABYTE GA-G31M-S2L
Ram: 4GB G.Skill
CPU: Intel Core 2 Duo E8400 Wolfdale 3.0GHz 6MB L2 Cache
HDD: WD 500GB (Tempting purchasing two and setting up a Raid configuration since I will have no backup solution.)
Due to the size restrictions, I am unsure which Graphic card to get. I am looking for the best bang for my buck. I don't need top of the line. Same goes with the PSU. Also, I am looking for a quality CPU cooler that will fit in the case.
Also, I am planning on swapping out the fans that come with the case and replace them with quality ones. I have AS5 here already.
Any help and suggestions would be much appreciated. Thanks.
Any help would be great
Case: Lanbox Lite
Ram: 4GB G.Skill
