snitzle_iii
- Aug 24, 2004
i bought a xm100 250g from tiger direct because people were saying it was a good deal and it was cheap 89/250gb ssd. this is my first ssd and has been causing way more headache than i had expected. The main hd is 80g
got the computer to recognize the drive then i formatted and used acronis to make a clone of the drive. the computer had difficulty keeping straight the Letter of the old hd and ssd. i changed the boot order to load the ssd first, but sometimes i would get a bsod and an error telling me to chkdsk /f the drive! i think i figured out a temporary solution to the problem. to disable the hd in windows, BUT then i was reading around on the internet how its important to have the ssd connected to a SATA 6Gb/s vs SATA 3Gb/s to receive optimum speeds. my mobo is ga-880ga-ud3h http://www.newegg.com/Product/Product.aspx?Item=N82E16813128444 . the thing has 6x sata 6 and 2x sata 3 ports. then i read how i should have hsci (sp) enable.
what is worse is that i basically began tinkering and updated my bios (friends suggestion) didn't save my oc and or my settings since i used gigabytes windows bios updating program. so i have the latest bios, but now my computer is acting all funny/crazy/weird. my computer will show that my c drive as ssd, but have poor speeds. the F drive will show as the hard drive and have 400 MBps read and 100 MBps write...
i don't know what to do. i don't want to reinstall everything. i was hoping that i could clone the hard drive and get ssd speeds out of the box.
basically right now i am not optimizing the ssd
http://i.imgur.com/ATEWzho.jpg toshiba
http://i.imgur.com/iXRhhMl.jpg seagate usb3
http://i.imgur.com/AuxsQ5c.jpgwd black
http://i.imgur.com/QhGhWDH.jpg raid1 seagate
http://i.imgur.com/N9nraud.jpg ssd
all harddrives are 7200 rpm
crystaldiskmark
http://i.imgur.com/iI0bi6w.jpg
computer showing weird speeds. the hd of my old os shows 400 MB/s read?!
poor performance of the ssd (before issues with C and F drive swapping)
bios options for sata
this does not boot with this setting
ssd speeds and proper letter drive association
so either my bios won't see my ssd or i will try to load/boot from my ssd and have the bsod due to the chkdsk /f
crystaldiskmark
