On another note did you see any improvements in your gaming graphics?
Cool thanks for the info. I guess I'll avoid sli. and stick with single tv and card gaming.
I would personally do odd number monitor combos. IE: 1,3, or 5. If you do an even number of panels than the center of your view if using both while gaming, or movies, etc, will be right where 2 bezels meet.
the only exceptions would be top-down style games like Civilization, Diablo, etc. If you have an aiming reticle, you'll want odd numbers of screens.
additionally, if you're on Nvidia, the largest number of screens you can configure for NVsurround is 3. On 6 and 7 series cards that have enough outputs, you can use the DVI ports for the surround screens, and then HDMI or displayport for the 4th screen (if you're running SLI).
the largest number of screens for NVidia surround, regardless of the number of cards is 3+1.
the largest number of screens supported per card is 3, although older ones will only be capable of doing 2 screens per card. the largest number of screens you can support on SLI is 4 even if you don't have an Nvidia surround array configured.
if you need more than 4 screens with NVidia, each card will have to remain in a non-SLI configuration.
I remember hearing way back that not all fps games will support sli and its a pain to maintain and config. Any truth to that?
