Hey hardforum, I was planning to buy another laptop but found this forum in my search and was immediately interested in having desktop hardware that could be moved across the country without expensive shipping costs.
1. What will you be doing with this PC?
Gaming, overlocking (maybe), Mathcad, matlab, photoshop, browsing
2. What's your budget?
I'd like to keep it around $1,000. I'd go up to $2,000 at the maximum (including shipping) if it brings worthwhile performance.
3. What specific features do you need in a motherboard?
Need: USB 3.0, SATA 6Gb/s, Ethernet, reliable for my general hardware (list at bottom)
Want: Effective overclocking, WIFI
4. Does this system need to fit into a particular space?
It MUST fit in a carry-on bag
5. How comfortable are you with custom case design/modification and electrical wiring? What tools do you have (Screwdrivers/Leatherman, Drill, Dremel, Metal snips, Soldering Iron, Bending Brake, CNC/Welding machines/Plasma cutter, etc...)
As this is my first SFF build, I wouldn't want to do too much more than adding ventilation unless it would be extremely beneficial. However, all of the above tools and more are available to me
6. Do you already have a legit and reusable/transferable OS key/license?
I will use a new 64bit Windows 7 key
I plan to build now or in late March. I want to build now because of the GTX560ti 448, but I don't really need the computer until early March. Are any major hardware releases expected between now and March that could effect this build?
Current parts list (* are items I am strongly considering):
*CPU: i5-2500k http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
*GPU: GTX560 Ti 448 http://www.newegg.com/Product/Product.aspx?Item=N82E16814127615 (I dont know if this will fit. Newegg lists as 9.57" long, thoughts?)
*Case: PC-Q11 http://www.newegg.com/Product/Produ...-na-_-na&AID=10440897&PID=3891137&SID=rewrite
*Heatsink: AXP-140 http://www.xoxide.com/thermalright-axp140-heatsink.html
*Fan: Thermalright TY-140 http://www.thermalright.com/products/index.php?act=data&cat_id=16&id=97 or Scythe Gentle Typhoon http://www.scythe-usa.com/product/acc/051/d1225c12b1ap_detail.html (should I be concerned about fan durability when used as a carry-on?)
MoBo: ASRock Z68M http://www.newegg.com/Product/Product.aspx?Item=N82E16813157268 (the overclock feature looks nearly worthless to me. Suggestions for a cheaper MoBo without OCing?)
PSU: ? (I want modular, but reading through posts here it seems they don't fit as well. Suggestions?)
HD: ? (I am thinking about an SSD+1TB)
RAM: ? (probably 4gb, maybe 8gb)
