First SFF Build, Proposed Part List, PSU?
OhMegaJ
Hey there! I've lurked this forum for advice before, and now I'm finally upgrading from a 3-4 year-old ASUS gaming laptop (which doesn't game anymore...) to a small-footprint desktop build. I have filled out the template, and below it listed the parts I am considering. As I mention at the bottom, I'm confused by the power supply part of this equation and would appreciate any advice on that, and anything else you notice.
In advance, thanks a million! :)
SFF Template:
1. What will you be doing with this PC? Gaming, Photoshop (or other intensive programs), Overclocking, Web browsing, strictly HTPC/Playback, etc. (If you have multiple things you want to do with the system, make sure you rank them from most important to least important).
  • Gaming, Adobe Illustrator, Corel Painter, Overclocking (total noob)
2. What's your budget? Are tax and shipping included in this budget? Is your budget flexible? Is cost a driving factor in component selection?
  • Budget is ~$1500 (shipping and tax not included)
3. Where do you live? Do you have any big B&M (brick and mortar) computer chains nearby (e.g. Microcenter, Fry's, etc)?
  • Toronto. TigerDirect, Infonec, NCIX, all sorts of other places I'm sure
4. What exact parts do you need for that budget? CPU, RAM, case, etc. The word "Everything" is not a valid answer. Please list out all the parts you'll need.
  • Case, mobo, CPU, heatsink, rear case fan, videocard, SSD boot drive, HDD, Win 7, ODD, RAM, PSU (see part ideas below template)
5. If reusing any parts, what parts will you be reusing? Please be especially specific about the power supply. For reused parts, list brands, model #s, and, if applicable, firmware revisions.
  • No
6. What specific features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc. Which is more important, size of the system or having the particular feature? Make sure you indicate *required* vs. *wanted* for each feature you list.
  • SSD support *required*, USB 3.0 *required*, Good built-in audio *wanted*, Overclocking tools *wanted*
7. What resolution output do you need? 1080p, 720p, DVD quality, etc for HTPC or list Vertical/horizontal resolution for non-HTPC SFF rigs. Do you need multiple monitor output?
  • 1080p, No multiple monitors
8. Does this system need to fit into a particular space? Think entertainment center shelves, closet space, rackmount, etc.
  • No physical space restriction
9. How comfortable are you with custom case design/modification and electrical wiring? What tools do you have (Screwdrivers/Leatherman, Drill, Dremel, Metal snips, Soldering Iron, Bending Brake, CNC/Welding machines/Plasma cutter, etc...)?
  • Would prefer not to get into that level of modification this build
10. How important is the noise/silence of this sytem? HTPCs typically want to be quiet while all-out SFF gaming rigs don't care
  • Quieter than my old ASUS G1S-B2 laptop (classmates make fun of it)
11. How mobile does this system need to be? Need a carrying handle or carrying straps? Is weight important (carry-on bag, etc)? Water cooling quick disconnects, etc?
  • Mobility not an issue
12. Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? Is it 32bit or 64bit? Remember that OEM copies of Win7 have issues with new motherboards
  • No, I have a Windows 7 Upg that, from what I read, is now tied to my laptop OEM license; is this right?
13. When do you plan on building/buying the PC? Immediately, in a couple weeks, 3-5 years?
  • Ready to order today
Here's what I've worked out so far:
Case - SILVERSTONE Temjin Series TJ08B-E Black Aluminum front panel, steel body MicroATX Mini Tower Computer Case ($99.00)
Mobo - ASUS Maximus IV Gene-Z LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard ($179.99)
CPU - Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor ($229.99)
Heatsink - XIGMATEK Intel Core i7 compatible Dark Knight-S1283V REV.W with ACK-I5361 120mm Long Life Bearing CPU Cooler I7 i5 775 1155 ($52.99)
Rear Fan - COOLER MASTER SickleFlow 120 R4-L2R-20AR-R1 120mm Silent operation Red LED case fan ($12.99)
Videocard - EVGA 012-P3-2068-KR GeForce GTX 560 Ti (Fermi) 448 Cores Classified 1280MB 320-bit GDDR5 PCI Express 2.0 x16 ($299.97)
SSD - Crucial M4 CT128M4SSD2 2.5" 128GB SATA III MLC Internal Solid State Drive (SSD) ($199.99)
HDD - Seagate Barracuda ST1000DM003 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive ($129.99)
OS - Microsoft Windows 7 Home Premium SP1 64-bit - OEM ($109.99)
ODD - ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk - OEM ($22.99)
RAM - CORSAIR Vengeance 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CML16GX3M4A1600C9 ($88.99)
PSU - ??????????????????????????????????
Subtotal: $1426.88
***I am totally ignorant when it comes to power supplies and electrical terminology. I tried using eXtreme Power Supply Calculator Pro, but it spit out a Recommended PSU Wattage of 396w, and that sounds really low to me... Any help on this matter would be greatly appreciated.***
Critique of my proposed parts is also most welcome. Also, is a fan controller necessary or more of an aesthetic thing?
A pretty solid start.
I would choose a different heatsink, because that one seems a bit pricey for only having three heatpipes. The Sandy Bridge CPUs don't get that hot even when overclocked, so most savvy and budget overclockers are using cheaper heatsinks.
You can probably leave out the rear fan. It only helps CPU cooling, and there will be a fan on the CPU cooler which will effectively push air out the back anyways. Only add it if you are having CPU overheating problems, which I'm pretty sure you won't.
Do Adobe Illustrator and Corel Painter need that much RAM? If the versions you have are not specifically 64-bit, then they are probably limited to 2GB RAM. Also, games are for the most part limited to 2GB RAM. If so, then just get an 8GB (2x4GB) RAM kit and save some money.
Yes, such a system will probably never use more than 400W of power. The trick is to find a 400W power supply with the two PCIe 6-pin connectors needed for the graphics card. That's the goal - find the lowest wattage PSU that still has two PCIe power connectors and is of decent quality. 500W models will have two connectors. Just make sure to get a decent quality unit and not one that is crappy. For instance, do not get Logisys or Diablotek. Antec (except maybe their lowest BP/VP lines), XFX, Corsair, Seasonic, FSP are usually decent. OCZ, Cooler Master, Thermaltake, Ultra can be quite variable with some good units and some not so good units.
Thanks for your advice guys!
So this heatsink's $20 cheaper:
XIGMATEK LOKI SD963 92mm HYPRO Bearing CPU Cooler bracket included I7 i5 ($29.99)
http://www.newegg.ca/Product/Product.aspx?Item=N82E16835233081
I will leave out the rear fan.
I looked into it and you're probably right about me not needing that much RAM. I suppose if I was messing around with video editing in the future, but I can't afford a second HDD at the current prices (after knowing what they once were..)
So I checked the mobo manual for compatibility and am going with this instead of the Corsair 16GB:
G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 ($45.99)
http://www.newegg.ca/Product/Product.aspx?Item=N82E16820231314
I think I've narrowed it down to two power supplies:
Seasonic SS-560KM Active PFC F3, 560W ATX12V V2.3/EPS 12V V2.91, 80Plus Gold Certified, Modular Power Supply ($123.49)
http://www.newegg.ca/Product/Product.aspx?Item=N82E16817151098
SeaSonic S12II 430B 430W ATX12V V2.3/EPS12V 80 PLUS BRONZE Certified Active PFC Power Supply ($74.99)
http://www.newegg.ca/Product/Product.aspx?Item=N82E16817151074
I would love have a modular power supply, and it says it has a good efficiency rating, but if the 430W is going to cover all my needs and end up being even more efficient, I'll go with that. Thoughts?
Man, I was looking at the prices you listed and thought why is everything more expensive, then I saw that you linked newegg.ca which seems to have a lot more shipping cost than the US in addition to price ><
The RAM you listed will work fine, but there's also their newer 'X' counterpart for the same price : http://www.newegg.ca/Product/Product.aspx?Item=N82E16820231428
probably no difference and there's a low voltage version that's $3 more : http://www.newegg.ca/Product/Product.aspx?Item=N82E16820231477
For the heatsink, I would use a Coolermaster Hyper 212+
http://www.newegg.ca/Product/Product.aspx?Item=N82E16835103065
It uses a 120mm fan instead and costs the same once you consider shipping cost on that Xigmatek.
For the PSU, you basically need to go with modular because of the low amount of space between the PSU and ODD in the TJ08. There's not going to be much space to route extra cables and you'll want to be under 160mm depth on the PSU. The Seasonic SS-560KM should fit, but another consideration is this Silverstone Strider 500W
http://www.newegg.ca/Product/Product.aspx?Item=N82E16817256065
It's shorter and modular but only Bronze vs Gold. I've been using it in my HTPC for 6 months and have had no issue.
In the meantime, a few of the parts went out of stock, so I discovered this other site DirectCanada (looks legit: http://www.resellerratings.com/store/Direct_Canada) that has comparable prices, but shipping's "free"/included. So splitting my order up with them is saving me about $30.
Yeah I'll go with the "X" series, because apparently it's exactly the same hardware, just with slightly cooler-looking heat fins.
I'm apprehensive about getting that heatsink instead because this is what the case's specs list:
  • Limitation of CPU cooler - 165 mm
...and that Cooler Master heatsink is:
  • 158.5 mm (H)
...and the XIGMATEK is:
  • 134 mm (H)
I compared the SilverStone Strider PSU to the Seasonic SS-560KM and the TJ08-E specs actually say 160 mm depth is fine. (180 mm is max)
I don't know if the Strider PSU does the same, but Seasonic is also advertising "Fanless Mode" when under 20% load (on the product page for the SS-560KM), plus it has 5 year warranty instead of 1... so I don't mind paying a premium for those features.
Plus, LOOK AT THE VELVET BAG :eek::eek::eek: http://www.youtube.com/watch?v=wFVZalnAtBU&t=1m51s
FINAL BUILD
Case - SILVERSTONE Temjin Series TJ08B-E Black Aluminum front panel, steel body MicroATX Mini Tower Computer Case ($97.72)
Mobo - ASUS Maximus IV Gene-Z/GEN3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard ($189.99)
CPU - Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor ($228.70)
Heatsink - XIGMATEK LOKI SD963 92mm HYPRO Bearing CPU Cooler bracket included I7 i5 775 1155 AMD and dual fan push pull compatible ($29.99)
Videocard - EVGA 012-P3-2068-KR GeForce GTX 560 Ti (Fermi) 448 Cores Classified 1280MB 320-bit GDDR5 PCI Express 2.0 x16 ($303.90)
SSD - Crucial M4 CT128M4SSD2 2.5" 128GB SATA III MLC Internal Solid State Drive (SSD) ($189.69)
OS - Microsoft Windows 7 Home Premium SP1 64-bit - OEM ($111.30)
ODD - ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk - OEM ($19.24)
RAM - G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBXL ($45.99)
PSU - Seasonic SS-560KM Active PFC F3, 560W ATX12V V2.3/EPS 12V V2.91, 80Plus Gold Certified, Modular Power Supply ($123.49)
PASTE - Arctic Silver 5 Thermal Compound - OEM ($12.99)
Subtotal: $1482.99
...annnnd Shipping, Shipping Insurance (for the "Free Shipping"), EHF, and 13% HST: $229.18
Grand Total:
$1712.17
Technically, it does fit my original $1500 budget, as I specified shipping and tax was not included. A big thank you to everyone for all the advice.
I'm just looking forward to building it next week, certainly taking some pictures and posting them in the SFF gallery, and subsequently shitting myself in sheer awe of its speed.
