Hello all,
I’m going to be building a server machine soon and wanted to get some opinion on the list of components that I’ll be putting together.
Everyday use (my only machine)
Multiple VMs at the same time (Windows 7/8/server, Linux)
Cisco network emulations: GNS3/IOU, VIRL, Nexus 1000v through nested ESXi on VMware workstation/player
Gaming (very light to none for now)
$3000
U.S.
CPU (buy 2)
Intel Xeon E5-2620 v2 Ivy Bridge-EP 2.1GHz 15MB L3 Cache LGA 2011 80W Server Processor BX80635E52620V2
CPU Heatsink/Fan (buy 2)
SUPERMICRO SNK-P0050AP4 Heatsink for Supermicro X9DR3-F Motherboard
Motherboard (buy 1)
SUPERMICRO MBD-X9DR3-F-O SSI EEB Server Motherboard Dual LGA 2011 DDR3 1600
SSD (buy 1)
SAMSUNG 850 Pro Series MZ-7KE512BW 2.5" 512GB SATA III 3-D Vertical Internal Solid State Drive (SSD)
RAM (already have from old rig)
CORSAIR Vengeance 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ16GX3M4A1600C9
Case (already have from old rig)
COOLER MASTER CM Stacker STC-T01-UWK Black/ Silver Aluminum / Steel ATX Full Tower Computer Case
PSU (already have from old rig)
IN WIN COMMANDER IRP-COM1200 1200W ATX 12V 2.3 / EPS 12V 2.91 SLI Ready CrossFire Ready 80 PLUS Certified Modular Active PFC Power Supply
GPU (already have from old rig)
EVGA 04G-P4-3673-KR GeForce GTX 670 FTW+ 4GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card
6) Will you be overclocking?
No
1920 x 1080 (27in.), 1920 x 1200 (24in.)
ASAP
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
SATA 6Gb/s (1-2), total of at least 8 SATA ports, 8+ DDR3 memory slots, goal is to get 128GB total in the future.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Windows Server 2012 R2 Standard
If you see any compatibility issues or have suggestions on alternatives, I’m all ears. Thanks!
P.S.: I'll be increasing the RAM soon but just not yet. (end goal is 128GB)
$3000
U.S.
CPU (buy 2)
Motherboard (buy 1)
SSD (buy 1)
No
ASAP
