prne10
- Oct 26, 2005
This year is my first real attempt at OCing anything. I decided to go ahead and snag a G0 Q6600 and after 1 week of stability at stock speeds, I am OCing it. My specs are:
Q6600 @ (3.0Ghz)
Ultra-120/sythflex
Abit IP35 Pro
2x 2gb G.skill PC8000
Evga 8800gt @ 650
I figured that with PC8000 Ram, I should be able to just go 1:1 on ram and set my fsb as high as needed. As it looks right now, at 3Ghz I am getting 4 cores at 60C running prime95 (temps from speed fan).
I have a few questions, though:
1st) When I go into Abit Bios to look at the Vcore, it won't let me drop it below 1.225ish... anyone know why?
2nd) If I get a stable OC at 3.0Ghz and max temps at 60.. how much further do you think I should push it? Consider that my room is not very warm but sometimes I do run the heater... then again, I probably wont be putting the CPU to full power most of the time...
3) Am I understanding it right when I say that my ram can handle up to 500mhz FSB since it is effective 1000mhz DDR ?
Edit *My brain is fried... just finished finals and I totally forgot to add more*
Q6600 @ (3.0Ghz)
Ultra-120/sythflex
Abit IP35 Pro
Evga 8800gt @ 650
