Well, after doing some extensive reading after screwing up my ABIT AS-8 (long story, but the short of it is, I didn't ground myself properly and shorted out the mobo...wasn't really a mobo problem), I decided to up my X2 3800+ just a tiny bit, to keep up on a single-core basis with my friend's 3500+.
Followed the guide in the AMD Processors forum, did the Prime tests with Clockgen, reached a max HTT of 225 for both (even with vcore at 1.44v...eh, maybe mine just doesn't want to overclock too much). Alright, well, since I was only aiming for 2.2 anyway, 225 was just fine.
Upped the vcore to 1.44 just for stability's sake (I have a Zalman 7700Cu that keeps my processor at a breezy 35C-36C idle and ~43C under load; if I could OC any higher, I probably would, but I'm kind of hesitant after my Abit "mishap"), put the RAM down to 166mhz (5:4...I have Corsair ValueSelect PC3200 ram @ 2.5-3-3-8 by default, and I'm not sure of its own ability to withstand higher speeds, so I'm just keeping it there), put the HTT at 225 and kept the Multi at 10 and booted into Windows.
Everything seems fine so far...did I miss anything? Considering how much the replacement parts cost me when I killed my old mobo, I'm trying to make sure I got everything right, else it may be a while until I'm on a computer of my own again. ;P
My setup:
AMD Athlon 64 X2 3800+ @ 2.2 (220*10)
Zalman 7700Cu
ASUS A8N-SLI Premium
1GB (2x512) Corsair ValueSelect (2-3-3-8)
Antec TruePower 2.0 550w
eVGA GeForce 7800GT (@483/1120)
SoundBlaster Audigy 2
Maxtor 250gb (IDE), Western Digital 200gb (IDE)
[Edit] Also, what kind of performance boost can I expect to see? Obviously I'm not expecting anything major, but how much difference do you suppose 200mhz will make (particularly in games)?
Thanks in advance for any input.
My setup:
Zalman 7700Cu
