First real mod.
reins
Hello this is my first post here.
I have a Lian Li 65B with green sleving and blue cathodes. Also Green led fans on exhaust and Blue led fans on the intake. This weekend I will be starting my wire management by cutting a hole in my removable mobo tray and adding a second 80mm exhaust fan under the current one. I was wondering what you guys think would be a good first real mod for a newbie. I am hesitant to cut a hole in my 120 dollar case or paint but am willing to give thought to any of your ideas. I don't think I'll ever paint because I love the look of aluminum and I just paid for one of the best cooling pc brands on the market and I'm not about to put down a few layers of paint to heat things up. I am using none of my 3.5 bays and there are 3 5.25 bays not being used. I have no fan management and nothing fancy. I would like to do a PS1 portable screen mod but I haven’t looked into GPU requirements, I’ve heard that most ATI cards can but some of the nvidia flavor cannot.
-Thanks
Asus A8N deluxe
1GB Corsair XMS (512*2)
EVGA 6800GT 256mb
AMD 3500+ Vini
10000RPM western digital@74gigs
Asus A8N deluxe
EVGA 6800GT 256mb
AMD 3500+ Vini
If by that you mean you have no fan controller, you should really get one. Unless you like being bothered by noisy fans.
my pc is in my room and i have a total of 10 soon to be 11 fans (including everything not just case)they are led and i have cathodes running to so I figure i could sleep through anything but it is an option. it really isn't a mod though :( .
