booGamiHXC
- Jul 15, 2004
So after a long 4 month duration of stock speeds. I decided it was time to OC my rig again. So I go into my bios(ABIT ic7-g II with a 3.0c/ht P4) and change the settings to 230 which would land at around a 3.45 clockspeed. Reboot. And whaddya know, my HDs(samsung sata's) aren't showing up on the preliminary boot. So I reset the settings. And ponder..I then set the clock to 201. Boot's up just fine. I reboot, go into the bios again and set it to 204. Boot's up fine. 205. The HD will not appear on boot...
I figure it could be just these problems
-HD is damaged
-Motherboard was damaged in the process of installing it into my new case
-CPU?
Has anyone ever been confronted with this problem before?
Built this rig august of 04.
-HD is damaged
-CPU?
