defiant007
- Feb 27, 2006
http://www.tcmagazine.com/comments.php?shownews=19804&catid=2
You've seen the drawings, now it's time to get a glimpse of something 'real,' like the cooling solution of the upcoming flagship card from Nvidia, the GeForce 9900 GTX. Set to cool off one GT200 GPU with 240 Stream Processors, the heatsink can be viewed just below. Equipped with one fan, the cooling solution is quite long, it takes up two slots and has a design similar to that of the cooler use with the 8800 GTS.
From the second picture it looks like the GeForce 9900 GTX will have two 8-pin connectors for additional power and also triple-SLI support. Stick around for more info.
