First PC Build - Is this all ok?
Savy
Gaming, web browsing, emails, basic office functions like word & excel.
I'm looking to spend around £800, £900 would be an absolute hard maximum.
UK
Motherboard, CPU, GPU, RAM, Case, Power supply & ideally SSD & HDD too.
A USB mouse & keyboard.
6) Will you be overclocking?
No.
24 inch 1080p. I'll be looking add another in the near future.
ASAP
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Whatever would be suggested.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
No. I'd be looking to get windows 10 64bit unless there is a reason not to.
This build is mostly taken from another thread on this forum with a few changes such as the case & GPU.
https://uk.pcpartpicker.com/list/kZJHQV
Are there any obvious flaws with this build? Any upgrades for basically the same amount of money? Is the case going to be ok?
Thanks.
Any specific reason you are going with a micro atx board?
Perhaps think about another fan or two for the case.
The general idea of the build looks looks fine to me, just minor issues.
+1 on getting a H270 or Z270 instead. No problem with getting mATX if the board has the options desired. If you do go mATX, consider a smaller case.
If you do replace the mainboard, it might support faster RAM, so match that up.
About the only other fault I can find is the PSU. The listed unit is old and not as efficient. Look at getting a current, Haswell compatible gold-rated unit in the 400-500 W range. Seasonic is good, and the current EVGA and Corsair units are seemingly well-regarded.
No problem. The case, to me, seems weird with that half window. Either do a window or don't. I am always a "or don't" guy. That black box sits under my desk and my toejam-trolls rarely appreciate the lighting effects.
