Tonight was the first time I've overclocked anything in my computer. I never really ventured into overclocking because I didn't have any money to replace anything if something did go wrong while in school. After ordering a FX-55 from the newegg deal, which should arrive tomorrow, I now have a backup if something does go wrong so I thought I would give it a go. The system I used for my overclock is in my signature.
After reading up on about 2-3 tutorials and getting all the programs I needed, I felt I was ready to try this overclocking thing. Using Eclipse's guide I loaded up Clockgen, Speedfan, and Prime95. I set Prime95 to inplace toture test and used clockgen to raise my FSB by 2-3 every 15-30secs. I now got my FSB up to 244 which sets my processor running at 2200mhz and my ram at 200mhz. Ran Prime95 now for about 30mins and played FSX for about 1hr to make sure everything was fine and dandy.
Now I'm sure the processor can go farther but the reason I stopped at 244 was because now my RAM was back up to where it was before I used up all the 4 ram slots. Before I used only 2 slots and they were running at 200mhz, but when I upgraded my RAM to 2gb using up all 4 slots it set itself to 166mhz. Now my questions are:
-=How far do you think I could push my RAM at default voltages?
-=Is raising the FSB the only way to push my processor faster since my multiplier seems to be limited to x9?
-=At post it says the ram is running at ddr333, when I check cpu-z in windows it says 200mhz...does that not mean its running DDR400 or am I royally confused?
-=When I get my FX-55 do you think I will be able to push the FSB to 244 again to be able to reach 200mhz for the RAM or is there another way to set my ram back to running at 200mhz?
-=Now I'm interested in overclocking my videocard, where would you guys say to go to get started in that?
Sorry for what seems to be easy questions...but I would rather know than be ignorant and mess something up.
Thanks for the tutorials BTW
