First OC 2400 35W Mobile XP
maxse
Ok guys I just got my NF7 board and 35W Mobile XP 2400 proc.
Im running at 43 degrees idle.
2.53 ghz (220*11.5)
My memory is I think is like 350MHz. Even though I have DDR400 RAM my computer crashed when it goes to like 400 Mhz.
Is there any way that I can relex timings or something so I can set a divider to 400Mhz and my computer will work?
I think 440 is the closest number above 400. By the way is my oc any good? How does it compare to the P4?
I can't really understand what you are saying ubt i thinkn you are running your memory async
you should try to keep your memory divider at 1:1, so your memory should be running 220MHz (440MHz), AMD's don't like to be async
Try loosening your timings to something like 2.5-3-3-11
run your memory 1:1... loosen the timings to start... go down to like 200 x 12... and work the fsb up a few mhz at a time
I cant seem to find the 1:1 divider. Is the SPD? or something. I have a regular NF7.
Also which memory time do I losten there are a bunch like CAS, etc... Thanks a bunch.
