Hey everyone,
First, here are my system specs:
Maxtor 200GB SATA 7200rpm
WD 80GB IDE (backup, I suppose)
DFI Ultra Infinity II
AMD Athlon XP 2500+
Friday night when I went to go shut off my computer I was surprised by the fact that everything basically went along fine until my system hung when the screen was black and the fans and everything were still on. As in, there was nothing I could do outside of hitting the power button. Yesterday morning I woke up, tried turning on the computer, and found that I got the BSOD with error code 0x0000007B and an "inaccessible boot device" error. I did a little reaserch and came to the conclusion that there just happened to be a bad sector on my drive. I went to the recovery console in DOS and tried running a CHKDSK from C: (my main SATA drive) but it said "invalid volume". I already had a Max Blast 4 bootable CD (which doesn't do any diagnostic work) and it seemed to detect my SATA drive fine. When I used Maxtor's Powermax program, the SATA isn't seen at all and only my WD is detected.
So now I'm stuck. I don't know what to try next. I'm hoping the drive isn't a bust and I can maybe salvage some papers and letters I was writing.
any help would be GREATLY appreciated. thanks in advance.
AMD Athlon XP 2500+
