First Mod. Unreal/eMo mod
emoretared
Just got most of it done today. i droped the CC light out and im replacing with some LED fans i ordered. But you get the idea. Going to put some molding on the top window and put the last piece of plexiglass behind my name. I put screen on the inside of the holes on the sides also. Pls comment, all good(if any) and bad. Thanks.
[EDIT] I know i suck with a Dremel, my first time using one also.
[Update] 2-18-05
Pic 1
Pic 2
Pic 3
UPDATE Pic 4
UPDATE Pic 5
Jesus, you're all from Indiana too?
Don't cry, Emo-kid, it's not a bad looking job, but go get some files and clean it up a little bit.
Hell I couldnt do anywhere near that job with my dremel! Nice job. I like the color of the paint too. Metalflake is always cool!
DaRkF0g said:
Neat fan! Where did you find that at?
negative, not a neat fan. file down those edges, unless those horrible cuts represent your shattered soul drownding in a sea of tears. emu4lyfe!!1!!1!!
How many Emo kids does it take to screw in a lightbulb? Well, one to screw in the lightbulb, one to form a band about it, one to write a poem about it, one to start a website about it, and the list goes on.
Ahhh, my favorite emo joke =). Anyways, about the case. I like it, good color. One thing though, grab a file and fix up those edges mah main man. Also, if you can, try straightening the fan so the grills go like "+" instead of like "x", also try to fix the molding around the fan so there isn't a "<" kind of gap in it. After that I would concur that you've made a pretty damn nice case.
Yea the molding is hard as hell to get perfect. Its was a really tight fit and i had the length right, but when i put the fan through it spread it a little. I might file, but i ran out of money for now, just gonna put molding on the top. Cant fix my name really, i did all i can with it, the more i mess with it the worse it will look. Here the link to the fan. . It was originally going to be a HS fan but it came and it is a 92mm fan not a 70, it doesnt even come clos to fitting in my case so, i just cut a hole in the side and threw it in as a HD cooler. Thanks for the replies.
Very nice, clean mod Emo, I'm going to be getting plans together to paint my case and add my name to it somewhere as well. You give me ideas ;)
...and replace that soundblaster sticker with a minor threat :D
/better yet - 7 seconds
Just put Bright Eyes stickers all over it. That'll really make it emo. ;)
Haha nice one fez. i actually did take the sound blaster sticker off because i pulled the card, i dropped a NV silencer 5 on my video card and got a plantronics usb headset.
