imExcitebike
- Nov 26, 2005
I'm building my first ever water cooling loop for my i7.
This is what I'm using, and have already purchased the CPU block and Radiator.
CPU Block: Swiftech Apogee XT
Radiator: Swiftech MCR320-QP-K
Pump: Swiftech MCP655-B
Reservoir: Koolance Body with Pump Nozzle & Base for the MCP655
Fittings: Bitspower 1/2 ID to 3/4 OD Compression
Tubing: Feser Red 1/2 ID 3/4 OD
Fans: ????
Right now its going to be Res -> Pump -> Rad -> CPU -> Res
I'm just doing a CPU loop right now, but plan on adding a full chipset block and a block for my 5850, but I'm wondering if the single mcp655 pump and 3x120 Rad will be enough for that full loop when its done.
Thoughts / Suggestions?
Fans: ????
