So I just installed my first heatsink...the infinity...jesus was that a bitch.
applying the thermal grease was a pain, and i'm not sure i did it correctly.
i put a little on the cpu, then used a clean razor to spread it the best i could.
it looked like i was scrapping some off in the process, so i put a little more on till i got a semi-even load across the plate.
then i did the same thing for the heatsink, mainly concentrating on the areas where it was going to come in contact with the cpu. (i cleaned it first with some rubbing alcohol and q-tips)
i installed using this guide
http://www.xtremesystems.org/forums/showthread.php?t=117054
but i'm not sure if i tightened down the infinity enough / too much. the motherboard seems to be bending a little...
so how / when am in going to be able to tell if i did it correctly? am i just going to have to wait till i boot up (assuming it boots) and see if the temp is in a reasonable range?
