Hey everyone,
ive been looking for new speakers for about a month now and finally decided to open up my own thread here. These speakers will replace my t20ii, so these are my first steps out of the low-fi (ok.. crappy ) speakers range. The more i listen to them, the more i start to get annoyed at the lack of midrange and the shitty bass...
Ive got a budget of about 200-250 for speakers, and narrowed it down to the following:
av40 -130/pair
A2/A5- 189/299/pair
M10/d1080mkii 08/d1010mkii08 ......
KRK rp5 300/pair
Hs50m 300/pair
Ill use these speakers mostly for music, most played music is:70s/80s rock, jazz, blues, classical. I dont need alot of bass and wont use them for any kind of mixing or DJing. Just listening. I think that therefore the HS50 and the Rp5 are less suited for me, i believe they are more orientated at mixing and a flat response. I want to listen to the music as its supposed to be, but im afraid that itll lose its shine if the sound is too flat.
Ive got 3 problems while choosing between these speakers. The first and most important is the fact that only webshops sell non-shitty speakers in (Holland), i probably wont be able to listen before i buy...
Second is that i dont have alot of space. I use a desk thats 115x78 cm (45x30 inches). Av40/A5 should fit easily, but the d1080mkii 08 is a tad too big i guess...
Third is my sound source, a standard laptop without any fancy soundcard. Ill get a DAC, probably a hrt streamer ii or a u202. The total budget id have for both is about 300-350 (400 if i get a superdeal somewhere).
The AV40s were my first choice (almost got them for 100 which is a good deal here...) but the more i read the more i start questioning if its the best sound quality i can get.. Some say that the 1080 is a lot better. Im interested how the 1010mkii compares to the av40. The main question for the A5 is: will the extra 150
One last thing about swans. Where can you get these babys in Holland(or anywhere in Europe), most webshops only ship to the usa and i havent found any webshop in Holland/belguim/germany that sells em.
Thanks for any advice, or extra suggestions that'll make it even harder to choose the "best" speaker for me
David
av40 -130/pair
A2/A5- 189/299/pair
KRK rp5 300/pair
Hs50m 300/pair
David
