InternationalHat
- Aug 13, 2004
I'm building a watercooling rig for my next box and I've started buying up components. Noise is somewhat important to me as my current machine whirrs along like a cropduster. After researching, I feel like the following parts will be best for me. I've never done this so any help/advice is appreciated. I'll be purchasing a lot of the parts this week and in 2 weeks when I get done with a project at work.
The system will flow in the following order with 1/2" tubing
1 - Danger Den cylindrical Reservoir
1 - Swiftech MCP655 Pump
1 - Quad Voyeurmods HeaterCore with 4 El Cheapo Yate Loon 120mm fans I'll eventually replace
1 - Swiftech Storm CPU block
1 - Dangerden brass Maze4 GPU cooler
using HydrX coolant as recommended by the pump
The reason for the extra-large heatercore is that it'll be mounted outside of the case. I'm running fairly low CFM fans on it, and the ambient temp is rather low(around 65F). I like the look of it and it'll fit fine on the side of the giant full tower this is all going in.
I'll likely be cooling a system(being built somewhat later, within a month or a month and a half by the end) that consists of:
AMD 3800 x2 Oc/d
DFI LANPARTY UT nF4 Ultra-D with a Zalman passive heatsink
2 gb pc4000 OCZ ddr
7800 GTX(whatever brand is cheapest when I'm ready to buy)
Antec TPII-550watt PS
Emu 1820M(uses a molex)
Intel PCI Ethernet adapter
2 optical drives
and 2 200-250gb WD IDE drives until I have the extra money laying around to buy SATA2 drives
The case will have a 120mm in, a 120mm exhaust and possibly another 120 mm in and exhaust which could put the total up to 8 120's running off this PS. I'm getting a fan controller to drop them down to around 5-7v.
Is the W/Cing setup reasonable? Should I be looking at different blocks/pumps? Will the power supply be ok for this or should I be looking at 600 watts? Thanks for any and all help.
AMD 3800 x2 Oc/d
2 gb pc4000 OCZ ddr
2 optical drives
