First ever OC.
BioInclined
So this seems to be a situation of TONS of info but only some is critical.
I was going to plan to use AOD(AMD OverDrive) for a very basic OC. Maybe just 3.4GHz, stock is 3.2GHZ.
Has anyone had good or bad experiences with it? Suggestions for using it?
I don't want to push hard on my current system for the reasons of I may be doing a new build end of summer and giving this one to a friend and don't wan then to have a "stressed" system.
My next build i will plan ahead on OCing a bit more.
All components are in the sig.
EDI: I just read a lot of negative reviews on this program. I suppose i'll uninstall it and just try to BIOS OC like it's supposed to be done.
