jibbonacci
- Aug 21, 2010
I currently have an older dual-Opteron system that I use to run freebsd as a fileserver using ZFS and providing NFS and Samba to clients, and also running a couple download daemons. I want to upgrade this box, and since processors today have more power than needed for such a setup I was thinking of virtualizing this system using ESXi. I'd like to get your opinion on what CPUs and how much memory I should be getting to run these VMs:
- freebsd running ZFS and providing NFS/Samba
- linux distro (probably Ubuntu) for development
- linux distro (possibly Ubuntu server, GUI may not be necessary) to run a couple damons for downloads and squeezebox server
- linux distro to run a perforce server and a small DB (to be used mostly for testing, nothing too instensive)
- windows 2008 server for some development work and audio/video encoding
I was looking at the Intel solutions, I'm just not sure if I should go with socket 1156 or 1366, and if I should get a dual socket motherboard (not sure if 4 cores would be enough to run the above). I was thinking either the Supermicro X8SIL-F with the Xeon X3440 and 8 GB of RAM, or the Supermicro X8STE with the Xeon E5620 and either 6 or 12 GB of RAM depending on cost.
Any opinions or suggestions are welcome.
