natermeister
- Dec 26, 2005
I've been tired of running out of space on my various computers and having files stored on one but not the other, ect. I know that building a file server isn't going to help with the 'running out of space' problem, but it should put it off for awhile. At least until I can afford to build a bigger, better file box in a year.
Motherboard Supermicro X7SBi
Processor Xeon L3360 (gonna run F@H on it)
Memory 8GB Crucial DDR2-800
HBA Areca 1210
Hard Drives Western Digital 1TB RE3
Chassis Supermicro 1U (four hotswap bays, got it for free)
I decided on the low power Xeon because I'm running this in a 1U case so the reduced heat dissipation would seem to be worth the extra money. Ram is so cheap that I figured I might as well populate the board. I also could probably get away with the onboard RAID, but it's dog slow for RAID 5 and I can always use the controller in another system build later on.
I'm not sure what to do about the OS. I had though about putting it on a CF card, but I figured that writes would eventually kill it. I think I might have to figure out a way to put a 2.5" hard drive in there or just maybe pop for a 2U chassis.
For the record, I'm probably going to use CentOS unless my brother (a teacher) can secure me an academic copy of Server 2008.
HBA Areca 1210
