I'm ordering parts for a new computer in about a week. This will be my first build as I've only bought pre-built junk before. I'm going to use it for gaming, HDTV/DVD playback, programming, and the usual screwing around on the web. Another top priority is too keep the entire system quiet when it's not under load. I also really need it to stay useful and mostly upgrade-able for 1.5-2 years.
I have these new parts already:
Case: Antec SLK3000B ATX (probably ships tommorow)
Monitor: Viewsonic VP191b 8ms
Mouse: Logitech MX518
Here's what I'm planning to order:
CPU: AMD Athlon 64 3200+ Venice [$192]
Motherboard: DFI LANPARTY UT nF4 Ultra-D ATX AMD Motherboard - OEM [$135]
PSU: SEASONIC S12-500 500W Power Supply - Retail [$137]
GFX: XFX PVT45GUDF3 Geforce 6800GT 256MB [$353]
+ Arctic Cooling NV Silencer 5 (Rev. 2) [$27]
Sound: Creative Labs Sound Blaster Audigy 2 ZS [$65] after MIR
RAM: OCZ Gold Series 1GB (2 x 512MB) 184-Pin DDR [$164]
HDD: Seagate Barracuda 7200.8 250GB 3.5" Serial ATA150 [$133]
Floppy: NEC Black Floppy Drive [$11]
DVD+RW: NEC Black IDE DVD Burner Model ND-3520A BK [$49]
Speakers: Creative Inspire P7800 7.1 [$90] (probably at a retail store, so I can return them if they suck.)
Misc stuff:
Logitech Elite USB Keyboard [$30]
Round floppy cable [$10]
Round ATA133 cable [$10]
THERMALRIGHT XP-90 Heatsink [$42]
+ A quiet fan for that, suggestions? [$10]
2xArctic Silver 5 Thermal Compound [$20]
Arctic Silver ACN-60ML (2-PC-SET) Thermal material Remover [$11]
(I'll be needing these to install the NV Silencer 5, I think.)
8xUSB 2.0 extension cables 10ft [$20]
10ft DVI cable [$21]
Total: $1530, before tax. Ouch. (I'll afford it, somehow.)
Notes:
Don't want SLI, never will.
I'm sticking to AMD 64 because I'm gaming.
Almost certainly going with an NVidia card because I consider the ATI drivers and control panel sub-standard.
After I get everything up and running, I'll try to overclock the 3200+ to around 2.4ghz (along with memory) and the 6800GT maybe 15% higher or so.
Questions:
1) Should I buy slightly cheaper RAM, or are the 2-2-2-5 worth the $40?
2) Anyone have that power supply and can comment on the noise level?
3) Should I use the stock HSF that comes with the 3200+ first, or should I just replace it with something else?
4) Anything significantly quieter than that NEC burner?
5) Do I need another 120mm case fan for the Antec SLK3000B case, or is one fine?
Just for laughs, here's my current POS:
Dell Dimension 4600
Intel Pentium 4 Northwood @ 2.6GHz w/ HT; 800 MHz bus
2x256MB (512MB) value ram @ 3-3-3-8 timings
Radeon 9800 Standard (can't even run at Pro speeds)
250W PSU
HDD: SAMSUNG SpinPoint P Series SP1614N 160GB 7200 RPM IDE Ultra ATA133
Sound Blaser Live! Dell (this thing crashes in EAX mode)
NEC 2.4/4X DVD+R only burner
(no floppy drive)
JBL 2.0 Speakers
Misc stuff:
Notes:
Questions:
Dell Dimension 4600
250W PSU
(no floppy drive)
JBL 2.0 Speakers
