This is based on the new Gigabyte GA-X38-DQ6 MB. I had been planning / working on this for a few months now and after the X38 board arrived last week I put everything together.
MB = Gigabyte GA-X38-DQ6
CPU = Q6600 G0 Stepping FPO/Batch # = L731A364
Memory = PATRIOT DDR2 2GB PC6400 DUAL LLK (4GB Total)
Video Card #1 = XFX 880GTX 768MB
Video Card #2 = Generic GeForce 7600 GS (for 2nd & 3rd monitors)
SoundBlaster X-Fi
Power Supply #1 = Antec True Power 2.0 550 (just for the MB & main HDs)
Power Supply #2 = (behind not visible) generic 550w for all fans, pumps, other drives, etc)
2 x 150gb Raptors
Monitor #1 = Dell 30
Monitor #2 = Dell 20
Monitor #3 = Dell 20
Case = Cooler Master Stacker Case - Painted in my garage
D-TEK FuZion CPU Block
Laing DDCT-01 18w pump with Petra Top
76 Chevy Caprice Heater Core
Reservoir from PVC elbows.
10 x 120MM fans (4 x on the rad, 3 x on the bottom of the case, 2 in front of the drive cages, one in the back)
1 x 92mm fan (attached to the waterblock to blow on the X38 Chipset )
Speed = 3690 (410 x 9)
3DMark Score = 7692 @ 2560x1600
Very stable at the clock speed so far, Prime 95 on all cores, etc
Some pics below, more here:
SoundBlaster X-Fi
2 x 150gb Raptors
