Wysockisauce
- Apr 21, 2012
Long time lurker here. Decided to make an account since I'm building my first PC from the ground up.
1) The PC is for gaming and general computing.
2) Budget is $4,000 but I'm not looking to spend $ for the sake of e-peen.
3) I live in Chicago.
4) I'll be buying everything so Monitor, Mouse, Keyboard, Computer
5) I wont be reusing any parts.
6) I will be overclocking
7) I'm looking to game at 1080p
8) I'll be building as soon as I can get my hands on a 690gtx
9) I don't need any specific features on the mobo but having them for the sake of upgrades etc. would be nice.
10) I will be buying a new copy of windows 7 64 bit.
I want to make a pc that's fairly mobile since I'm going to be taking it with me when I travel. I've already done a bit of research and so I'm making this post to make sure I didn't miss any components that might be better for the money.
Case - LIAN LI PC-V354B (I wanted a langear dabox 100 but I cant seem to find them anywhere)
Psu - SeaSonic Platinum Platinum-860 860W (Probably overkill for these components but I'm looking to reuse it in future builds)
Mobo - ASUS Maximus V Gene
RAM - Mushkin Redline 8 GB : 2 x 4 GB Memory - DIMM 240-pin - 2133 MHz
HDD - Mushkin Enhanced Chronos Deluxe 240GB (Will be the only HDD in the system)
CPU - Core i7-3770K
GPU - 680gtx
Cooler - Antec KUHLER H2O 920e (Will be mounted on the exhaust vent)
Monitor - Dell UltraSharp U2412M
Keyboard - Ducky Shine DK9008S - Green LED Mechanical Keyboard (Red Cherry MX)
Mouse - RAZER Naga Hex
Disk Drive - ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner
Case Fans - GELID Solutions FN-FW12PL-18 120mm Green LED Case Fan (Will replace the stock blue fans)
Any comments are appreciated, thanks in advance.
CPU - Core i7-3770K
GPU - 680gtx
