1) What will you be doing with this PC? Gaming mostly, multitasking, browsing
2) What's your budget? $1,500
3) Where do you live? Delaware
4) What exact parts do you need for that budget? LCD, MB, CPU, RAM, GPU, PS, Case, HDD, OS, DVD drive, CPU cooler
6) Will you be overclocking? Yes once I read about it more
7) What size monitor do you have or plan to have? 22" Samsung LCD
8) When do you plan on building/buying the PC? NOW!
from browsing the forums this is what I have come up with so far:
Intel Core 2 Quad Q9550 http://www.newegg.com/Product/Product.aspx?Item=N82E16819115041
ASUS P5Q Pro http://www.newegg.com/Product/Product.aspx?Item=N82E16813131299
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 http://www.newegg.com/Product/Product.aspx?Item=N82E16820231122
Western Digital Caviar SE16 WD6400AAKS 640GB http://www.newegg.com/Product/Product.aspx?Item=N82E16822136218
SAMSUNG Black 22X DVD+R http://www.newegg.com/Product/Product.aspx?Item=N82E16827151171
Antec EA650 650W http://www.newegg.com/Product/Product.aspx?Item=N82E16817371015
Antec P182 Gun Metal Black http://www.newegg.com/Product/Product.aspx?Item=N82E16811129025
EVGA 896-P3-1265-AR GeForce GTX 260 Core 216 896MB 448-bit GDDR3 http://www.newegg.com/Product/Product.aspx?Item=N82E16814130398
XIGMATEK HDT-S1283 120mm http://www.newegg.com/Product/Product.aspx?Item=N82E16835233003
XIGMATEK ACK-I7751 Retention Bracket http://www.newegg.com/Product/Product.aspx?Item=N82E16835233019
SAMSUNG 2253BW Black 22" 2ms http://www.newegg.com/Product/Product.aspx?Item=N82E16824001268
Microsoft Windows Vista Home Premium SP1 64-bit http://www.newegg.com/Product/Product.aspx?Item=N82E16832116488
Arctic silver 5
Total: $1,476.37
one question I have is about the antec case and the power supply being on the bottom will it have any problems reaching the mother board?
also does anyone see anything that needs improving?
Arctic silver 5
Total: $1,476.37
