First Build
Planenutok
Im a long time lurker first time poster. Ive finished my first build a couple of weeks ago and i could not have done it with out you guys.
Specs
Thermaltake XaserV WinGo V7000D Blue Computer Case
Asus A8N-SLI Deluxe mobo
amd 3700+ san diego
2xGIGABYTE Geforce 6600GT GV-NX66T128D Video Card in SLI
Thermaltake TR2 W0070 430W Power Supply
G.SKILL 2GB (2 x 1GB) 184-Pin DDR SDRAM Dual Channel
Maxtor 300 GB Sata HD
Sony DVD burner
Lite on dvd rom
Win XP Pro
Logitech X-530 speakers
So far everything is running great. It does everything i want it to do plus some. Any comments or suggestions appreciated. Thanks BR
My old comp was a P4 2.5 ghz laptop. It worked great for me for 4 years then i decided i needed more power. Plus my bro had just finished his custom rig and i had to beat it so i did. About the only difference between mine and his is i have sli and about 100 more gigs hd space.
