first build won't post...
iotiX
I'm getting one long beep, and two short beeps when i try to start my computer. This is really detrimental to me as its my first build... argh. :(
Specs:
ASUS A8N-VM Socket 939
ONBOARD NVIDIA GeForce 6100 Micro ATX AMD
AMD Athlon 64 3500+
2xG.SKILL Value 1GB 184-Pin DDR SDRAM DDR 400 (PC 3200)
help?
videocard? make sure its seated properly and has power to the card if it has a connector.
also, you should have a 24pin and a 4pin connector for power to the motherboard, make sure both are in.
my video is onboard... is there a connection i need to make to the mobo that i missed perhaps? the 24 and 4 pin connections are in place at the moment
again, it's my first build, go easy please
I would think it would default to onboard video without a problem. Is that award bios on that board?
Like most first time builders (including myself), you probably didn't read the motherboard manual did you? J/K, but seriously, you should be able to find a section on POST Beep codes that'll tell you what those beeps mean. Probably a memory or power issue. Check that book!
lol, i read the manual. there is no part of it where it talks about error codes or beeps. i looked it up online.
incase you wanna check it out for yourself:
MANUAL LINK
"it's my first build, go easy please"
PC Virgins at there finest lol
1long 2 short indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information.
Just googled 1 long 2 short beeps =)
Clear cmos or maybe toss in a pci/agp/pci-e whatever it has, just to get to bios...maybe a bios setting that uses on board video. Could be that, by dfault, its off. Only thing i can think of with that those error beeps.
problem is, i don't have an extra video card. perhaps my mobo is just faulty? should i just try my luck with their customer support?
Have you tried resetting the BIOS? take one stick of RAM out and clear the BIOS and then try again. Can we have full system specs inc case and psu.
It could be, sure there isnt a jumper or something to enable the on board video?
You did clear the CMOS right? Make sure you remove the battery too. If that doesn't work, pray to the computer gods and clap your hands and spin around three times. Works for me;)
Had this same problem on my ASUS board, I could be wrong, but at least for my mobo M2N-SLI Delux 1 long two short actually ment faulty ram. I switched out the ram and it worked perfectly, so if you have other ram you can test with, give it a go.
switched out RAM, and it didnt help. the tech guy who tried to help me when i called their tech support told me to take out my ram entirely and see if i get a different beep error, but I still got the same one. He then told me to RMA the mobo, so i have to RMA it back to newegg and hopefully i'll get a working mobo. Kinda a disappointment to me since it was my first build... but what can you do :(
thanks for all the help anyway guys, i appreciate it
i got the same thing on mine when there was no ram in it, are you sure it's the mb and not the ram?
Cheer up buddy. You did good. It was Asus who didn't uphold their part. If the new mobo is good, you should be ready to go!
Sometimes you get a DOA piece of hardware. I've seen hard drives die with less than 12 hours of power applied to them. I always get computer-build-virgins coming in wanting to build a computer up for the first time. If I get a good vibe from them, I don't mind letting them use my workbench space. I do keep a very close eye on them and give them tips/tricks/warnings along the way. I'd compare that to being a nagging wife, but I'm not married and I don't want to anger any of the [H]ardWomen here. :p
Do you have a friend who is comfortable with building machines who might have been able to help you out?
Asus are really good when it comes to changing parts.
I am doing A+ and coincidently i am doing beep codes and it was the video card which wasnt configured properly , those of you who got it right get 5 points. ;)
Give yourself a pat on your shoulder.
I have had 35% asus boards which i have had to swap but they are still one of the best boards for overclocking out there.
Also dont worry if its your first build , you got to the posting bit next time you will get to the drivers. :D
IOTIX you did good , :)
