System is as follows.
Asus A8N-SLi non deluxe.
AMD 64 3700+ San Diego
1 Gig Corsair value ram
Leadtek 6800GT
420w PSU
WD 37gb 10k rpm HDD
With just these wired up and the system turned on, i get all the fans running, CPU, GPU, Chipset, and all case fans just fine. GC and motherboard have green Leds and appear to be fine. However, there is NO output to the monitor. I have checked the connections over and over again, including a CPU connection problem which i corrected (im pretty sure anyway). Is my MB or GPU totally screwed or am i missing something?
Leadtek 6800GT
420w PSU
WD 37gb 10k rpm HDD
