First build, some questions
PigCorpse
Wow, I'm pretty close to getting a new computer. Almost urinated myself!
Anyway, here is what I have planned so far:
CPU:
Opteron 146, if I can get a good stepping.
If not, or if I can't get one at all, then an Athlon64 3200+ Venice.
$180 at most
Graphics card:
I'm thinking maybe a 6600 256MB PCI-E. The one I have in mind is this:
http://www.buyxg.com/store/item.asp?key=VC-135-209
$105
Case:
I'll go off to www.amamax.com and get something less than $45.
$45
HDD:
Already have an almost new WD Caviar 200GB 7200RPM ATA-100.
RAM:
Already have 256MB of DDR400. I'll definitely upgrade when I save up some.
Optical drives:
I already have all I need. But I want a DVD burner for less than $40.
$40
Everything else I have, except the mobo.
Now, I want an nForce4 chipset. I don't know which.
I REALLY want this one: http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=247031
But it's out of stock and I don't know if that's the right price.
Otherwise, I'm considering:
- Asus A8N-E
- Abit KN8
- MSI Neo4-F
Which is the best of those? I'm looking for stability, performance, and I might overclock if I need to. But mostly stability and speed. And I'm open to suggestions, but it has to be less than $110.
I'm trying to stay under $450 in total (if I don't buy a DVD burner).
You will be very disappointed if you don't upgrade the ram to 512 or a gig. If you don't want to bottleneck that video card (or if you want to run xp worth a damn) 512mb is an absolute must, and a gig is better.
Go for a 6600gt.
Yeah, as soon as I get the money, I will upgrade to something like 1 GB of RAM.
I'm not much of a gamer, so I think a standard 6600 is fine.
What kind of performance difference will I see if I get a 6600GT?
