§urfÅceÐ
- Aug 26, 2005
Hi all. I've enjoyed computers for a while, and last year I decided that it was time I built my own.
So for the past two months I have been collecting parts, and I finished this week when my 8800GT arrived (thanks Newegg). Now I have to put everything together. In the past I have done single-part upgrades, such as sound cards, GPUs, and RAM with only rubber gloves. But this is my first time starting from scratch. Also, I've got the whole wisdom of age thing against me, because I'm a stupid 14-year-old
I have heard a few basic things but I want to verify them all and ask a few of my own questions. My appreciation for truthful, 100% guaranteed-correct answers is totally unaccountable (while it may be a hysterical prank for you, its won't be quite the same for me). Please, please, please be as comprehensive as possible.
I'll probably add more questions later as they come to mind.
Thanks
- First, what clothing should I wear? The minimal? Just boxers? No socks?
- I will be either working on my varnished hardwood floor or my bed, depending on which is safer (the former, yes?).
- I am pretty sure that a grounding strap for my wrist is essential this time; the nyplex gloves won't be reliable. What is an ideal metal object that I should attach the alligator end to? Should I still wear the gloves anyway?
- Okay, so we've got the mid-tower ATX case. The Corsair PSU goes it first, right? Do I plug the AC cord into an outlet before putting anything else in? Do I then power it on before putting anything else in, or is that a total no-no? (I have seen some people say its good, but far more say its bad).
- Is an I/O backplate for the motherboard highly important? I believe it is, but I want to be sure. Does this get installed before the PSU, or after (if after, when)?
- Should I connect cables (y-splitters, IDE, SATA, MOLEX, etc) immediately after installing the part they are for, or after installing all of the parts? (probably after: it would be easier to put on lock ties)
- For applying my thermal compound, what should I use as a squeegee?
- Are there any very good videos around the web of people building PCs?
Thanks
