First build, some help w/ my decisions?
Scherdy
Ok, this is my first build. It'd be mainly used for gaming, music and very basic digital photography. I don't have any interest in OC-ing (for now anyway). I'm not a graphics man-whore so I don't have to have everything turned up all the way... but it'd be nice ;) We have about 1200-1400 to spend.
First question, the 3500 is about 90 bucks cheaper. Is it still worth getting the 3800?
2) This I know the least about. I want reliability/efficiency w/ my CPU. Prob don't need SLI for that 2nd video card really. Any other suggested products and explanation would be great.
3)The 6800GT 512MB flavor is $50 more...and the 7800 GT is 60 more after rebate. Should I just do myself a favor and get the 7800?
PSU- Antec Smartpower2.0 500W sufficient and reliable I think.​
4) The 240 pin version is about $50 less. The 184 pin is what I need though right? Just making sure here.
NEC DVD burner my best guess going by the sales and what others have chosen here.​
Thanks ahead of time. I really only know what I've read on here so all feedback is appreciated.
3 suggestions:
go with the 3700+ San Diego.. 1mb cache
go with the ASUS mobo
and do ur self a favor, and u'll be thxking ur self, get the 78GT
Asian Dub Foundation said:
3 suggestions:
agreed, and get crucial value ram......id go with 2x1 gig sticks since you seem to be future proofing your rig....and yes 184 pin is what you need , 240 pin is DDR2 ram for intel rigs.....
and get the "True" power series of Antec's psu's.......not smart power
soulsaver_8229
soulsaver_8229
Thanks, I appreciate it. Is crucial just more reliable? Or is it just a personal preferance?
The "true" power vs smart power...do I need the same wattage for the True? And just wondering what the true series has/does over the one I had. Noise? More efficient? Saves energy etc? I have no problem spending 20 dollars more on a psu, but definitely need some details as to the differences.
crucial 1 gig sticks are about the cheapest available. good reliablility. good warrantee. where's eclipse?
the diffrence is, i dont think you know enough about computers to use a smart power as you can bump up the 5volt rail i believe? not intirly sure........
and speaking from experince i have a truepower 550, not the 2.0 verion, just single rail....
its great antec psu;s are solid as a rock, i think youll like the truepower better
and yes cruical will yeild better stability, and typiacaly longer life span.....plus lifetime warentee
soulsaver
soulsaver
are there any memory manufacturers who don't offer RAM that carries a lifetime warrantee? crucial, schmucial. if you can spring for corsair sticks, do that as they seem to be pretty SNAFU-proof, elsewise just make a list of 1gb sticks that fall within your budget and throw a dart at it.
