Programming and software development, moderate gaming (I would like to run HL2, TF2, L4D2, etc. at their highest settings at 1080p; I also have a couple of flight simulators: DCS, and Falcon 4 BMS), as well as potentially some media work.
Would like to keep it around $1350 inclusive.
Bay Area, California, USA.
CPU, motherboard, memory, storage (SSD + HDD), video card, case, PSU, optical drive, OS (Win 7 Pro 64-bit).
23" Dell 2312hm. Keyboard + mouse.
6) Will you be overclocking?
Most likely not.
1080p, 23 in.
Within the coming month.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
USB 3.0, Sata 6Gb/s, onboard audio.
No.
** I would also like my build to be relatively quiet. **
I have the following tentative set up:
CPU: Intel Core i7-3770K 3.5GHz Quad-Core Processor ($319.99 @ Amazon)
Motherboard: ASRock Z77 Extreme4 ATX LGA1155 Motherboard ($132.98 @ Newegg)
Memory: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1600 Memory ($79.99 @ Newegg)
Storage: Western Digital Caviar Black 1TB 3.5" 7200RPM Internal Hard Drive ($91.99 @ SuperBiiz)
Storage: Samsung 840 Pro Series 128GB 2.5" Solid State Disk ($129.99 @ NCIX US)
Video Card: EVGA GeForce GTX 660 Ti 2GB Video Card ($269.99 @ Newegg)
Case: Corsair 550D ATX Mid Tower Case ($149.99 @ Best Buy)
Power Supply: Corsair Professional 750W 80 PLUS Silver Certified ATX12V / EPS12V Power Supply ($104.99 @ Newegg)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($24.98 @ Newegg)
Operating System: Microsoft Windows 7 Professional SP1 (OEM) (64-bit) ($139.99 @ Newegg)
Total: $1424.88
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2012-12-13 17:49 EST-0500)
I am considering a GeForce 660 instead of a 660 Ti, as well as the Corsair 600T case (in white). I would like a case with easy cable management, and dust filters. Is it worth getting a WD black over a Seagate Barracuda? Furthermore, is it worth investing in a non-stock cooler?
Thanks in advance.
Most likely not.
1080p, 23 in.
No.
Total: $1424.88
Thanks in advance.
