Hi all,
Well the time has finally come for me to build a new PC. The following is what I have in mind:
Motherboard: Abit IP35-Pro (http://www.newegg.com/Product/Product.aspx?Item=N82E16813127030)
CPU: Intel Core 2 Duo E6850 (http://www.newegg.com/Product/Product.aspx?Item=N82E16819115028&Tpk=e6850)
CPU Fan & Heatsink: Tuniq T-120-LFB 120mm (http://www.newegg.com/Product/Product.aspx?Item=N82E16835154002)
Case: Cooler Master Stacker 830 Evolution (http://www.newegg.com/Product/Product.aspx?Item=N82E16811119103)
Video Card: EVGA GeForce 8800GTX 768-P2-N831-AR (http://www.newegg.com/Product/Product.aspx?Item=N82E16814130072)
RAM: Crucial Ballistix 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (http://www.newegg.com/Product/Product.aspx?Item=N82E16820146565)
Power Supply: PC Power and Cooling Silencer 750W Quad (http://www.newegg.com/Product/Product.aspx?Item=N82E16817703009)
Hard Drive: I have a Seagate 120GB 7200rpm IDE and a Seagate 500GB 7200rpm IDE. I'm looking to get a 500GB 7200rpm SATA drive.
CD/DVD Burner: LITE-ON LH-20A1L-06 (http://www.newegg.com/Product/Produ...=&Subcategory=5&description=&Ntk=&srchInDesc=)
Monitor: LG Flatron L246WP (will buy from Best Buy)
Speakers: Logitech Z-2300 (http://www.newegg.com/Product/Product.asp?item=N82E16836121122)
Sound Card: Sound Blaster X-Fi XtremeGamer Fatal1ty Professional Series (http://www.newegg.com/Product/Product.aspx?Item=N82E16829102005)
This system is mainly for gaming, photoshop, programming, and some video/audio editing. I prob won't be overclocking very much. The budget is $2000 or less and I'll be buying the components from the US.
I'm open to suggestions on all components except on the cpu brand, graphic card series, and the monitor.
Thanks so much in advance!!
Nico
Nico
