First Build.. *sigh*.. Help :( -- Pictures
Alright guys. I finally dished out some money and built a computer. I have:
asus a8v deluxe
amd 64 3500+ w/ stock heatsink+fan
1 wd 80gb hd
NEC Disc Drive
2x512 sticks of Corsair XMS PC400 RAM
MGE Vigor 450W PSU ( Pre-sleeved/two fans )
I put it all together on my kitchen table and flipped the switch on the PSU. Only thing that happened was a green light on the mobo went on. No fans spun. The PSU has lights inside and 2 fans.. It didn't light up nor did the fans spin. Pictures..
http://www.blizzcenter.com/comp/
HELP!!
If the power switch from the case is not attached then that is all that should happen.
First I would switch the PS off and disconect the drives. You dont need them untill you want to install your os.
Then switch the PS back on. Now short the two pins the power switch should attach to with a small screwdriver for one second. That should turn it on.
Once you have built it a little further, you can get into the bios a set it to turn on with the power not the switch.
Luck........ :D
Ah Short out the power supply? I'll wait on that one heh. I plugged in the "pwr switch" 3 pin thing from the case into its location on the mobo. I pressed the botton with the PSU on and no dice. Does the front panel need to be plugged into the power supply for it to work?
no , but there should be two power cables going into the motherboard. you also need a video card, it goes into that brown slot on the mobo, and a monitor...dont see them in those pictures :p
that's the first thing i noticed. you didn't plug the smaller connector coming from the psu. it is for your cpu. i would suggest that you consult the manual that came with your motherboard. it's pretty detailed and should guide you through everything.
I know where the video card goes :).. I try not to be that ignorant. Turns out there was a red switch on the PSU for 230/110 volts I think. It was on 230 which didn't work. So its fixed thank god. I'll build it now and repost pictures. Any ideas why?
Thanks
also, how would you turn the "pc" on if you don't have the switch connected yet. the switch you turned on earlier is only for the psu and not the whole computer.
You dont "need" a vid card for it to turn on but you wont know whats happening.
Thats why I said disconnect the drives.
But you do need to plug the ATX12V 4 pin power connector in.
Good call, I missed that.
The power switch is a 2 pin connector, the power led is a 3 pin one.
Have you got the right set of wires/connector.
Plus your heatsink fan wants to be plugged into the CPU_FAN header not the PWR_FAN header.
Some mobo's wont turn on if they dont find a heatsink fan.
Luck........ :D
Lol. Getting a nice amount of help here. Thanks a lot guys. I'll upload some pictures first thing tommorow.
Looking at it now, so far so good. It turns on, fans spin, hds make noise, etc. Only thing is, it doesn't always turn on? Sometimes I have to switch the psu on and off a few times, wait a few seconds for the green led to unlight on the mobo, or just fiddle around. Any ideas?
I haven't plugged in a monitor yet. May do that next...
There are all these pin connectors and I can't find a clear diagram on where they actually go? I have an asus a8v deluxe mobo and a antec p160 case. The p160 has tempature probes, a front panel, etc. The front panel has all these extra junk like a mic hole/speaker hole etc. I can't figure out where to plug it in? Can someone help?
Thanks!
well if you want to turn it on you have to connect a switch to the respective power pins
or just take a metal object like a screw driver and touch the two pins ( two pins most of the time) at the same time that will act as a switch and turn the machine on
two pins = power circuit
all the information should be in the manual
it will show you where to connect the power on cables, hdd light, and reset
very easy imo
It isn't exactly clear.. Some are horizontal while other are verticle.
Also, can a temp probe be mounted under the heatsink?
All asus motherboards come with a sticker that shows the motherboard listing all the conections such as power, reset, USB, Firewire, Audio, etc. About the temp probe, I believe the two wires with plastic over the ends are the temp probes, you can try to rig them to hang around there, but it is not necessary. You can always use ASUS Probe, an application on the CD that came with your motherboard, to view motherboard/CPU temps. One way to get the probe mouted around the heatsink is to tape it to the bar going across the case so it hangs down around the heatsink.
Yeah, I always seem to connect a lead or two backwards when working on a new board. Sometimes you've gotta experiment a little...
As long as the temp probe doesn't interfere with the contact between the heatsink and the cpu, you should be able to stick one there.
Thanks for the reply...
I can't find that sticker?'
I made a diagram with the connectors and the pins at the bottom. If someone could spend the time to match them up by making a line from the connector to its pins(circle the pins), I would greatly appreciate it.
http://img62.exs.cx/img62/763/mobo.jpg
Also, there are USB ports in the front.. How do I connect them?
RTFM. :mad:
Pages 2-28 to 2-32.
Internal USB cables are coloured red-white-green-black.
Starting at the 1 pin just plug them in in that order to either UBB56 or USB78.
Look how that back pannel header fits then follow the same colours with the front.
The case headers are on page 2-31.
Just follow the diagram.
If the led's dont work just plug them in the other way around.
Luck........... :D
theres also a +12v auxiliary power connector that should be going into the mobo, its black and yellow
I love the antec p160 case. It has a ton of great features and I would say its nice quality. Only downside is, it scratches like no other.. Also the front panel is plastic. I would give it an 8/10.
After hours of sitting here like an idiot, I brought it to my friend who then tested the PSU and determined its dead. Great! Now I need to go through the RMA process and wait a week to get a new PSU.
:rolleyes:
