Hey guys.
This is my first build so I'm afraid if I have made any noob decisions.
Decided to go for the E6600.
I'm on a slightly tight budget so that explains the low end motherboard. Should I go for a higher end? I'm not planning to utilize SLI though...
This will be mostly used for gaming.
Please check it out. Notify me of anything that isn't compatible, personal preferences, better choices, better prices etc...
Case
Lian-Li PC-65B
http://www.frozencpu.com/cst-49.html
140
PSU
HIPER ATX12V 580W
http://www.newegg.com/Product/Product.asp?Item=N82E16817128002
99
CPU
Intel Core 2 Duo E6600 2.40GHz
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2280512&CatId=1568
360
Motherboard
MSI P965 Neo-F Socket T (LGA 775) Intel P965 Express ATX
http://www.newegg.com/Product/Product.asp?Item=N82E16813130052
97
HD
Western Digital Caviar SE16 WD2500KS 250GB 7200 RPM 16MB Cache SATA 3.0Gb/s
http://www.newegg.com/Product/Product.asp?Item=N82E16822144701
79
RAM
CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM Unbuffered DDR2 675 (PC2 5400)
http://www.newegg.com/Product/Product.asp?Item=N82E16820145015
152
GPU
Geforce 7900GT KO 256MB
http://www.newegg.com/Product/Product.asp?Item=N82E16814130015
273
Fan/Heatsink
ARCTIC COOLING Freezer 7 Pro
http://www.newegg.com/Product/Product.asp?Item=N82E16835186134
35
Thanks a million guys.
Case
Lian-Li PC-65B
140
PSU
HIPER ATX12V 580W
99
CPU
360
Motherboard
97
HD
79
RAM
152
GPU
273
Fan/Heatsink
35
