This is my first pc build. Been a mac user. I needed a workstation, so this build is meant for photo/3D/paint work, not for gaming. The spec list is as follows:
QX6700
Gigabyte 965P-DQ6
G.Skill 6GB
150GB Raptor
320GB WD
XFX 7950GT XXX
Pioneer DVR-112D
FusionHDTV5 Express tuner
Koutech 1394B card
Corsair HX620W
Lian Li PC-A16
XP x64/*nux (not yet installed, probably Fedora Core 64)
To quiet the case I used Thermaltake noise dampening sheets with Super Soundproofing foam mats. All stock fans were replaced by Noctua fans. The HDs were place in Smart Drive enclosures.
To cool the case I have four 120 Noctua fans: one 1200rpm exhaust; one interior to cool the video card; and two 800rpm intake fans. Except for the exhaust fan, the Noctua fans are thermally controlled by the Noise Magic modules.
To cool the cpu I use the Tuniq Tower with fan. The fan is controlled by the motherboard. Haven't done any serious tests yet, but this is the core temp of the cpu under mild load:
Here is the rest of the image gallery.
The pc is dead quiet with the cpu fan running between 800-1200rpms. This weekend I'll test it under load to check on temps and fan noise. The cpu is currently running stock. With the already high temps, I don't know whether I'll overclock, but, I might give a try for a look see...
QX6700
Gigabyte 965P-DQ6
G.Skill 6GB
150GB Raptor
320GB WD
XFX 7950GT XXX
Pioneer DVR-112D
Koutech 1394B card
Corsair HX620W
Lian Li PC-A16
