First Build- is my component list compatible
You should be OK with those components, but you can save $20 to $30 by going with two kits of the following RAM:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231122
My home server is based on the following components:
Gigabyte GA-EP35-DS3R LGA 775 Intel P35 board
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128086
Intel Q6600 (B3 stepping)
8 GB of RAM (4 GB of Kingston DDR2-667, 4 GB of G.Skill DDR2-800; link above)
Two 200 GB Western Digital SATA drives (mirrored for the OS)
Six 750 GB Western DIgital SATA drives (RAID 5 for data)
OCZ StealthXtreme 600W PSU
Since it is my server, I don't overclock it as it runs 5 or 6 VMs and seti@home on the side.
I generally build in the case to start off, though if your case is cramped, you might be OK putting in the CPU and HSF before installing it in the case. Just be careful of ESD.
Vms?
ESD?
HSF?
A few days okay I thnk I snookered a power supply and board when a god damn 6 port 12V line hit a USB input and sparks flew.
I assume this is one of the cautoions you mention and static.
hey is static really an issue with todays coponents??
Ronan
VMs = Virtual Machines. I run VMWare on my server.
Electro-static discharge
Heatsink/fan.
Ronan
Static is always an issue, which is what I was referring to with my ESD comment. That's why I prefer to mount the board in the case and then the components in it, as it is less risky.
Ronan
Hi,
I think it depends on how the different modules are designed. The internal HW design requirements are different from vendor to vendor, some design for "fool proof" specs and assembly, while others are happy as long as they can get something working.
\\\Jens
