First build, in time for the holidays
iotiX
I've been putting off buying this build for a bit, since i've been waiting for the prices to go down. Anyway, i just can't wait anymore so please give back suggestions on how i can make this build cheaper/better. This is what i've gotten from the past few months, and it hasn't changed... much :D. I'd like to keep the 6800 gt, because i don't plan to upgrade until about june.
Case: Aspire X-Dreamer II(Black) ATX Mid-Tower Case
http://www.newegg.com/app/ViewProductDesc.asp?description=11-144-026&depa=1
Power Supply: Aspire 520W 12V Black Triple Fan Aluminum Power Supply
http://www.newegg.com/app/viewproductdesc.asp?description=17-148-008&DEPA=0
Monitor: ORION 19DFLB 19" Flat CRT Monitor Black Retail
http://www.newegg.com/app/ViewProductDesc.asp?description=24-162-109&depa=1
Motherboard: CHAINTECH nForce3 250 Chipset Motherboard for AMD Socket 754 CPU
http://www.newegg.com/app/ViewProductDesc.asp?description=13-152-043&depa=1
Processor: AMD Athlon 64 3000+
http://www.newegg.com/app/ViewProductDesc.asp?description=19-103-486&depa=1
RAM: Corsair Value Select (Dual Pack) 184 Pin 1G(512MBx2) DDR PC-3200 - OEM
http://www.newegg.com/app/ViewProductDesc.asp?description=20-145-440&depa=1
Video Card: eVGA Nvidia 6800GT
http://www.newegg.com/app/ViewProductDesc.asp?description=14-130-208&depa=1
Hard Drive: Western Digital Special Edition 80GB
http://www.newegg.com/app/ViewProductDesc.asp?description=22-144-122&depa=1
CD Drive: LG Electronics Beige 52X CD-ROM
http://www.newegg.com/app/viewProductDesc.asp?description=27-101-406&depa=0
Keyboard and Mouse REPLACEMENTS: KEYBOARD Combo PS/2 107keys Black
http://www.newegg.com/app/ViewProductDesc.asp?description=23-157-013&depa=1
~$1,100
I agree with Erfus about the power supply. Look at Antec, Thermaltake, Enermax or a larger reliable company like that. But if that's what you want then get it. I haven't heard much about aspire. Remember watt's isn't everything. There was an older post explaining that.
Good choices for everything else...just make sure that case has all the airflow you want, if so then you're good.
BTW...nice looking case.
...Dan
whats ur main budget?? for 25 bucks more u can ge 120gb
http://www.newegg.com/app/ViewProductDesc.asp?description=22-148-020&depa=1
also ...u NEED skt 939 even if u have to go 2800+, it will make future upgrades cheaper.
cd burners are about 30 bucks, cdr /dvd r combos are 60 bucks
and if u game u need a diff mouse...extended time on that 4 dollar mouse ur getting will hurt ur hands badly
and might i suggest this ram
http://www.newegg.com/app/ViewProductDesc.asp?description=20-144-305&depa=1 (just by 2 of em)
it comes with heat spreaders cause ram does get hot ... only 164 bucks for 1gb of it
