1) What will you be doing with this PC? Gaming? Photoshop? Web browsing? etc.
Quite a mix of stuff - gaming, media, heavy web browsing, programming, development webserver, some light Photoshop. I have an M-Audio Firewire interface, so I'll probably be using Cubase from time to time, but only basically (just recording and mixing a few tracks, few VST instruments if any).
No limit really.
3) Where do you live?
Ireland. I'll probably be ordering most of the stuff from dabs, some from komplett wherever cheaper, and the heatsink from Chilled PC since they stock the new Megahalems Rev.B with P55 socket support.
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
Case, PSU, motherboard, CPU, heatsink, RAM, graphics card, monitor, hard drives
I've already bought an Antec P183 on advice from a friend. I'll most likely be getting their proprietary PSU that matches it, the CP-850, unless advised otherwise.
6) Will you be overclocking?
I haven't done so before but I'm willing to try it with the build. System stability is much more important to me than maximum performance though.
Samsung T240 included below. I'd welcome suggestions for alternatives, bearing in mind that I'm pretty set on 1920x1200. I was looking at the Dell U2410 but this build is already getting very expensive...
ASAP - as mentioned I already have the case, and I'm ready to order the rest as soon as I'm definite on components.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Since I'm going with a P55 socket system, Crossfire is pretty useless (due to halving the bandwidth to each card). RAID could be an option; I don't know too much about it though. See below.
10) Do you already have a legit and reusable/transferable OS key/license?
I'll be getting a copy of Win7 Home Premium with this build.
I've never done a self-build before; but I've been getting advice from friends who are pretty experienced with it. I've picked out what I think is a reasonable set of components, but I'd appreciate some advice on it (and wouldn't be that surprised if I got "wrong kind of RAM, noob" back!).
Anyway, the build-in-progress:
133 Antec P183 Case ALREADY PURCHASED
122 Antec CP-850 PSU
204 ASUSTEK Maximus III Formula
262 Intel i7-860
£45 (~50) Prolimatech Megahalems Rev.B
26 Noctua NF-P12-1300 120mm 1300RPM Quiet Case Fan
109 OCZ 4GB(2x2GB) DDR3 PC3-12800 XMP Extreme Edition
235 Sapphire Radeon HD 5850 1GB GDDR5
259 Samsung T240
224 Intel X25-M 80GB G2 SSD (retail package with 3.5" mounting bracket)
265 Western Digital Caviar Black 2TB
87 Win7 Home Premium
...for a total of 1976.
Possible points of discussion:
Any suggestions or comments would be greatly appreciated. I've been specing this build for over a month now (I'm a little OCD when it comes to these things) and I'd really like to get it ordered soon!
Thanks,
eugeneius
No limit really.
262 Intel i7-860
259 Samsung T240
- Should I get a second PSU fan? The Megahalems Rev.B comes with two sets of fan clips, but how much of an advantage would this be, since I won't be heavily overclocking?
- The mobo supports RAID, but I don't know much about it. I chose the WD Black 2TB because of its performance here, but could a RAID setup perform comparatively or better? I could buy three Samsung Eco Green 1.5TB drives for less than the WD Black, and run them in RAID5. They spin at 5400rpm, which would be nice for low noise. I understand the seek time wouldn't be improved, but how much of a sustained throughput improvement could I expect from that setup?
- Graphics - I'm currently rocking an X600 Pro (lol) so no matter what I buy I imagine I'll be blown away by the difference. I'm pretty sure I want one of the new ATI 5XXX series cards, but I don't know about the price-to-performance ratio. Here's the cheapest price I can get each of the four models: 5870 - 331, 5850 - 235 (current choice), 5770 - 150, 5750 - 124. Considering I'd like to get back into gaming (I have friends pressuring me to join Aion, and I really like the look of Borderlands), and my res will be 1920x1200, is the extra 85 I'm spending to get the 5850 over the 5770 justifiable?
Thanks,
eugeneius
