First build, how far off am I?
bobjones
I'm 21 / college student, and am upgrading from a laptop which I've owned for the past 3-4 years. I've never built a computer before, but I'm usually a quick study with anything in the pc universe.
I'll be using it mainly for day to day operations (browsing, fruity loops, torrents...etc...), but once enemy territory:quake wars comes out, I'm predicting I will become thuroughly addicted. Even though I might do a fair amount of gaming, I don't see overclocking in my future. I'm mainly looking for dependability.
Here's what I have so far. Keep in mind I don't really know what I'm doing so any recommendations would be greatly appreciated. (I'm looking to spend around $1500)
Case: COOLER MASTER Centurion 5 CAC-T05-UW
http://www.newegg.com/Product/Product.asp?Item=N82E16811119068
DVD Burner: NEC Black 16X DVD+R 8X DVD+RW 8X DVD+R DL 16X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2M Cache IDE/ATAPI DVD Burner - OEM
http://www.newegg.com/Product/Product.asp?Item=N82E16827152058
Hard Drive (Changed): Western Digital Caviar SE16 WD3200KS 320GB 7200 RPM 16MB Cache SATA 3.0Gb/s
http://www.newegg.com/Product/Product.asp?Item=N82E16822136003
Memory (Changed): Crucial Technology 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 533 (PC2 4200) Dual Channel Kit System Memory
http://www.newegg.com/Product/Product.asp?Item=N82E16820146569
Monitor: ViewSonic VX922 Black/Silver 19" 2ms LCD Monitor 270 cd/m2 650:1 0.294mm Pixel Pitch
http://www.newegg.com/Product/Product.asp?Item=N82E16824116375
Motherboard (Changed): Intel BOXDG965WHMKR Socket T (LGA 775) Intel G965 Express ATX Intel Motherboard
http://www.newegg.com/Product/Product.asp?Item=N82E16813121052
Processor: Intel Core 2 Duo E6400 Conroe 2.13GHz 2M sharing L2 Cache LGA 775 Processor
http://www.newegg.com/Product/Product.asp?Item=N82E16819115004
Ok, so that's what I'm starting off with.
As far as a video card, I'll need some advice. As well as what kind of heatsink and power supply.
But outside of those three things, what else is missing? Do I need extra fans?
Thanks for any help.
First, I'd suggest the this Seagate 320gb over the WD3200KS. For the price of that crucial kit, you could get a good DDR2-800 kit, like this g.skill 2gb kit. Are you sure you don't want to OC? because conroes are real easy to OC even with stock cooling. If you want to be able to OC, I'd suggest the DS3 Gigabyte board instead of the intel one.
For PSU, I'd suggest the Antec SP2.0 500W modular PSU (the one i have, hehe). For graphics, go with a 7900GT. If you're doing mild to no OC'ing, the stock intel HSF will suffice.
Changed a couple things
Mother Board: ASUS P5W DH DELUXE/WIFI-AP Socket T (LGA 775) Intel 975X ATX Intel
http://www.newegg.com/Product/Product.asp?Item=N82E16813131025
Memory: G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 667 (PC2 5400) Dual Channel Kit
http://www.newegg.com/Product/Product.asp?Item=N82E16820231051
(thanks enginurd)
Hard Drive: Seagate Barracuda 7200.10 ST3320620AS (Perpendicular Recording Technology) 320GB 7200 RPM 16MB Cache SATA 3.0Gb/s
http://www.newegg.com/Product/Product.asp?Item=N82E16822148140
Video Card (Changed): SAPPHIRE 100149 Radeon X1900XT 512MB 256-bit GDDR3 VIVO PCI Express x16
http://www.newegg.com/Product/Product.asp?Item=N82E16814102003
First of all, that is an EXCELLENT motherboard. I just got one. I wasn't planing on overclocking either, but once i figured out how easy it was with that board and my e6700, I changed my mind. Even with the stock heatsink.
Second of all, I would advise against getting the Sapphire video card. I've never owned a sapphire, but i've read plenty of bad things about their customer support. If you can, I would go with a Powercolor card of the same type. Powercolor is the only ATI card maker that provides a lifetime warranty vs. a 1-2 year warranty with anyone else.
Have you thought about your power supply at all? I suggest you check out the power supply forums and at least check to see if you're getting a reliable brand. If not, your power supply could crap out and decide to fry all your hardware with it.
The MSI 975X Platinum is also good if you want to save a lil cash.
if you read through the newegg review of the zalman 9500 you'll notice the intel chips run very warm under stock cooling... just something to keep in mind. I've got a 7700cu zalman and my temps for my E6600 overclocked to 3.0Ghz are 35C. The 9500 may even do a batter job in cooling than that so for a system like yours I'd suggest a aftermarket heatsink/fan.
Looks like a great system once you pin down a powersupply.
Very good case you picked out - I have one and it's fairly quiet and the build quality is superb. Plus it's easy to work in :)
Power Supply: OCZ GameXStream OCZ700GXSSLI ATX12V 700W Power Supply 100 - 240 V
http://www.newegg.com/Product/Product.asp?Item=N82E16817341002
Video Card: POWERCOLOR 1900XT512OEM Radeon X1900XT 512MB 256-bit GDDR3 VIVO PCI Express x16
http://www.newegg.com/Product/Product.asp?Item=N82E16814131006
Heatsink: ZALMAN CNPS9500 LED 92mm 2 Ball Blue LED Light Cooling Fan with Heatsink
http://www.newegg.com/Product/Product.asp?Item=N82E16835118223
Thanks so much for the suggestions. Much appreciated.
First off, in general you've got an excellent build coming along.
My one suggestion at the moment though is to rethink your powersupply. It's overkill to the nth degree for that system. This PSU is cheaper and still enough to power a quad-sli system...also, don't bother with aftermarket cooling unless you're looking to overclock.
yeah, i was thinking that powersupply was a little overkill, but i figured too much is better than too little. but the one you linked to will work much better, thanks.
and as far as the heat sink is concerned, as mentioned above the intel chips run a little warm with stock cooling. and for $50, its 100% worth it to me to have the peace of mind in knowing that its super cool inside my case (and who knows...maybe i'll get bored one day and try my hand at a little overclocking now that i know its not too complicated).
thats what I like to hear!
Oh, I almost forgot, the price on that x1900xt is far too high; why not go with the sapphire model for about $100 less? Same RAM, same everything...
Conroes dont run as hot as previous intel chips. They actually run alot cooler. Anandtech tested OC'ing on the E6300 and E6400 with intel stock cooling and was able to reach 2.59Ghz and 2.88Ghz respectively -- those are stable overclocks with intel's stock HSF. So if you plan on running your E6400 above 360Mhz FSB (stock is 266), then you'll need an aftermarket HSF. Otherwise, don't bother. You can always buy an aftermarket HSF later on, when you plan on overclocking past the limit of the intel stock HSF. There will probably even be better coolers out there.
I had originally picked out the sapphire, but then this was posted
I believe it's a two year warranty, but I have to be honest: almost every faulty videocard is broken in the first few months of use, otherwise it'll usually last quite a while. I just don't see the reason for paying such an obscene premium for that warranty. If you're concerned about warranty then perhaps switching to the green side would make more sense because of the overall superior warranties.
Consider the 7900GTX and 7950GT, which both have lifetime warranties which cover aftermarket heatsink/fans as well. Hell, for cheaper than that Powercolor X1900XT is going for you could buy an X1900XTX (ATi, Sapphire, or Connect3d models are all at or below that price)!
eVGA has lifetime warranty and openly warrants their cards if the HSF was replaced with a 3rd party cooler (you just have to put the stock one back on if and when you send it back).
XFX has double lifetime warranty (on most high end parts), making the card easier to sell once you're done with it and want to upgrade. Replacing their HSF voids the warranty.
and BFG has a standard lifetime warranty.
I wonder why there is such a huge disparity between the warranties offered on the nvidia side versus that on the ati side...
