Hey everyone, I'm doing my first watercooling build and after a lot of research I think I'm ready to buy the components. However, I would love it if someone more experienced out there could tell me if I'm on the right path. So far my plan is to do a single loop (because of this) that will cool the following:
I still got a few questions though:
Thanks to anyone who responds, I really appreciate it! I don't wanna screw this up, so I'm trying to be as prepared as I can!
- Core i7 930 (Swiftech Apogee XT Rev 2)
- EVGA Classified Motherboard (Bitspower Black Freezer)
- EVGA 580 GTX Hydro Copper 2
- Radiators - XSPC RX360 mounted at the top of the case, and then modding the bottom to fit an XSPC RX240.
- Pump - Swiftech MCP655 with 3/8" conversion kit.
- Reservoir - XSPC Dual 5.25" Bay Reservoir and place my pump in it.
- Should I use the Feser Aqua coolant, or something else? Do the coolants with color leave residue on the loop over time? I think I've heard something about that on a few FrozenCPU reviews.
- Is one of those pumps enough for this single loop?
