First Build...Could use some help!
Gavin28x
Ok, well this will be my first build, and Im not trying to have this built by the end of the month or anything more like by the summer, so if theres anything I should hold off on, or anything I should pick up ASAP lemme know plz :). Anyway right now I still have a socket A athlon2800+ and AGP on the Mobo,(no pci-e for me!) so basicly I have to start over completey, even a new PSU.
This is what I've complied so far, it looks good to me (but im a n00b so what do I know). All these prices so far have been Newegg (gotta love the egg) and I havent picked out a new PSU because the case I have is a TT Armor and the way the HDD cage is set up makes it do the power supply can only really have a fan on the front or back not the top no bottom, at lest thats the way it would seem
I have AMD now and I've had no real problems with it, so i figgured id stick with AMD, I'd rather not SLI, I'd rather go with a 8800 VS two 7900's or something like that.
Mobo: ASUS M2N-E Socket AM2 NVIDIA nForce 570 Ultra MCP ~ 95$
(http://www.newegg.com/product/product.asp?item=N82E16813131022)
CPU: Athlon 64 X2 4600+ Windsor 2.4GHz ~ 199$
(http://www.newegg.com/product/product.asp?item=N82E16819103751)
RAM: CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 ~ 280$
(http://www.newegg.com/product/product.asp?item=N82E16820145590)
GPU: eVGA GeForce 8800GTS PCI-e x16 ~ 390$
(http://www.newegg.com/product/product.asp?item=N82E16814130071)
HDD: Seagate Barracuda 7200.10 ST3250820AS 250GB 7200 RPM ~ 75$
(http://www.newegg.com/product/product.asp?item=N82E16822148142)
CD / DvD - http://www.newegg.com/product/product.asp?item=N82E16827106047 ~32$
PSU- ????
I have a Case TT Armor, and a Sound card, Creative X-fi which is all i have for the new build. If I've missed anything or anything looks like its not compatable please dont flame me, like I said its my first build. I'm not big on OC-ing, nor WaterCooling, maybe on later builds or once I get a little more experiance. Right now I wanna do a good build but keep stuff at stock clocks at lest right now.
I'd like to keep its under 1200...which leaves about 150 for a PSU....if i really need to cough up more then I'll so it it will just take a little while longer, Im not in a HUGE rush.
Also I'll prolly hang my head and go get a copy of vista to install on this comp.
Anyway I hope I didnt embarrass myself to much, I've been trying to do some reading and get up to date with things so now I will turn it over to you gentelmen, Please be gentel :eek:
Intel Core 2 Duo E4300 Allendale 1.8GHz 2M shared L2 Cache LGA 775 Processor - Retail
BIOSTAR TForce965PT LGA 775 Intel P965 Express ATX Intel Motherboard - Retail
The above is a better combo as of right now. It is better for the $$$ than the AMD setup. In about another month or so Intel is gonna be dropping the price of the CPU down to about $113 so you could hold off on that for now.
CORSAIR CMPSU-620HX ATX12V v2.2 and EPS12V 2.91 620W Power Supply 100 - 240 V UL, CUL, CE, CB, FCC Class B, TUV, CCC, C-tick - Retail
Everyone is hung up on this Power Supply. Not much over the build total.
THANX!
So first off, right now does everyone bascily think that AMD cant stand up to Intel? and also with that PSU (cause i did look at it) that fan will be on the back wall of my case with about 1-1.5 inches of clearance with no vents in sight....is that gonna a problem?
As of RIGHT now AMD doesn't stand up to any of the C2D offerings. AMD has yet to release K8L (their next big upgrade) but there has been speculation of 10% - 40% faster than what C2D is now (take that with a grain of salt). Anybody asking about builds right now is automatically suggested C2D unless it is for HTPC or mATX since Abit has a nice AMD overclocking board for those.
