First Build - Buying Next Week, Advice?
Sczee
Hi,
I'm planning to build my first pc soon (I'll have the money next week) and before I spend the $$$ I'd like to check that everything I have chosen is sensible and compatible. Also it'd be good if it was decently future proof. I'd like to get a good two+ years out of it without any major upgrades (I know extra RAM might be a good idea if I get Vista sometime down the road but I don't consider that too major).
I will use it mainly for gaming and uni work but as uni work mainly consists of programming and simple simulations I'd say the gaming will be far more taxing.
What I plan to get is:
CPU: E6600 + Tuniq Tower
Motherboard: P5B Deluxe WiFi
Memory: 2x1GB Corsair DDR2-800 4-4-4-12
Hard Drive: Seagate 320GB 7200.10
Graphics Card: BFG 8800GTX 768MB
Optical Drive: Lite-On SHM-165H6S 16x DVDRW DL
Sound Card: X-Fi XtremeMusic
Power Supply: Corsair 620HX
Case: Silverstone TJ09B-W
I already have:
Monitor: ViewSonic VX922
Speakers: Logitech Z-5500 5.1
Keyboard & Mouse: Logitech Media Elite/MediaPlay Cordless
OS: Windows XP Pro
External HD (Backup): Seagate 300GB 7200.7 (I think)
The total of what I have to buy comes to about $2060 on Newegg but I live in New Zealand so I only give that as a reference to see if its a good system for the price (I have to pay 3884 New Zealand dollars :eek: ). I am planning to overclock it (obviously since I have the Tuniq Tower). I'd like to get at least 3.2GHz stable which sounds like it should be simple enough with the parts I've chosen.
Thanks for any replies.
Looks good. 3200/9 = 356Mhz... that setup should definately reach 3.2Ghz.
I can't find any flaws with that setup. Personally, i'd get a seperate drive for the OS, but seeing as you already have a spare backup drive i don't think that's necessary. If you want to save some cash you could forget about getting the soundcard and just use the motherboard's onboard sound.
Well I was thinking about getting a 74GB or 150GB Raptor for OS/Apps but decided against it seeing as the extra price you pay doesn't gain you that much performance. I'll just have a separate partition for the OS & Apps. Yeah I'm not completely set on getting the soundcard. I do have decent speakers though (well for computer speakers) and since I am going to be using it for games the higher EAX support would be nice so I think I'll stick with the soundcard, it's only about 6% of the total cost.
I would say keep the sound card. the Xfi xtreme music is a fantastic card... Makes everything sound awesome even in headphones. And its always nice to enable Ultra high sound with EAX enabled...
Awesome I'll definitely get the card then. Thanks.
